![]() | Home > Maintenance & Mods (L322) > fitted second battery in the back |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
Looks good, nice job |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
Which model Varta did you fit?
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Probably a silly question but I’ll ask anyway, what’s the purpose of fitting a second battery? Does it make a lot of difference in the day to day running? Just intrigued 2009 (2010 MY) 5.0 Supercharged Autobiography
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
It helps avoid the dreaded 'low battery - please start engine' warning. and it means you can listen to the radio with the engine off for more than 5 mins |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
hi james i think i understand what you are explaining . at the moment the second battery is switched on when ing key goes to first position using the green wire in the trailer socket . and it is charging all okay from the alt . so if i take a power live from the second battery in to a switch and then in to the 100 amp relay i can switch it by hand to energise the relay . can i piggy back into the same relay wires 85/86 ing live / and earth new vehicle purchase
My aux battery is a deep cycle AGM used to run a fridge that runs even when the engine isn't running, possibly overnight if camping. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
I would suggest a Voltage sensing relay to protect the main battery. You can get them that have an override switch and also work both ways ie if you charge the Aux or connect a solar panel once the Aux battery is full the relay switches and the main battery will charge. I would also recommend lifting the loom out of the battery area and securing it above the fusebox, there is enough length. https://www.australiandirect.com.au/Batter...U8QAvD_BwE 2007 TDV8 VSE
thanks wayneg for the advice i am waiting for a meter of elec flex tubing to come to wrap the loom to stop it from rubbing thanks oggy new vehicle purchase
