![]() | Home > Maintenance & Mods (L322) > Sagging rear |
Could be a leak or could be a faulty valve block or height sensor. It would be wise to invest in a GAP IID tool to save a lot of tail chasing….. 2012 TDV8 Vogue (L322) |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
No harm in pulmping it up to off-road height and switching off to listen for any leaks. That may give you enough access to get some soapy spray on there as well, just keep your hands clear in case the suspension should suddenly drop. 2016 Skoda Octavia VRS Estate
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 373 ![]() ![]() ![]() |
Will an iid pinpoint the issue to either the block or the air bag?
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Hi, sorry to hear about your issue. Have you eliminated a dodgy ride height sensor ? I don’t think they usually throw up a suspension fault warning but the car would drop, always worth checking the cheapest option first. Good luck in sorting it out. |
It’s just dropping on one corner. When weather improves I’ll take wheel liner off and investigate further cheers 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
