Home > Maintenance & Mods (L322) > TDV8 4,4 oil separator
RINOR
Norway 2012 Range Rover Vogue TDV8 Barolo Black
Regardin the 4,4TDV8 maintanace. Where is the crankcase vent filter (oil breathing filter, oil separator) located? I can only refer to the Volvo Penta D6 marine engine, were this is a serious important maintanance filter:) Would appreaciate comments to this, can not find were this is located . . . Thanks😊
Post #630409 2nd May 2022 3:29pm
GraemeS
The engine doesn't have a filter. A separator is located in the block under the EGR cooler which is under the oil cooler.
Google LR022761.
Post #630462 2nd May 2022 8:55pm
RINOR
Thanks!!!! Now I can hope for a video that walks us through the job😅😅
Post #630477 3rd May 2022 6:17am
JayGee
It’s not a service / maintenance job. Why do you want to do this? 2012 TDV8 Vogue (L322)
Post #630481 3rd May 2022 6:34am
RINOR
as mentioned in my first post, I compare with Volvo Penta's marine engine D6, where the crankcase filter is an important part of maintenance. I assumed that TDV8 also had this. why I am looking for solution is that I have periodic oil leakage and it comes from this area. I have replaced the two o-rings at the back of the engine. but it continues to leak😢
Post #630483 3rd May 2022 7:14am
JayGee
The leak is almost certainly from the oil cooler seal - it's such a common fail item it should be a service item. 2012 TDV8 Vogue (L322)
Post #630487 3rd May 2022 7:35am
GraemeS
Hopefully the new gasket part numbers indicates that the gasket material has been improved.
Post #630494 3rd May 2022 8:31am
RINOR
Many thanks for answers! But does this mean there are more O-rings to replace in this area? I did replace the two on the one tube between firewall and oilfilter (behind oilfilter).
Post #630752 6th May 2022 6:43am
JayGee
You need to remove the oil cooler from the top of the engine to replace the main seal. Plenty of how-to’s on this if you use the search function. 2012 TDV8 Vogue (L322)
Post #630753 6th May 2022 6:46am
RINOR
Thank you very much👍🇳🇴😊
Post #630757 6th May 2022 7:28am
