Home > Maintenance & Mods (L322) > TDV8 4,4 oil separator |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
The engine doesn't have a filter. A separator is located in the block under the EGR cooler which is under the oil cooler.
2nd May 2022 8:55pm |
RINOR Member Since: 10 Oct 2021 Location: VIKEN Posts: 7 |
Thanks!!!! Now I can hope for a video that walks us through the job😅😅 |
3rd May 2022 6:17am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3207 |
It’s not a service / maintenance job. Why do you want to do this? 2012 TDV8 Vogue (L322) |
3rd May 2022 6:34am |
as mentioned in my first post, I compare with Volvo Penta's marine engine D6, where the crankcase filter is an important part of maintenance. I assumed that TDV8 also had this. why I am looking for solution is that I have periodic oil leakage and it comes from this area. I have replaced the two o-rings at the back of the engine. but it continues to leak😢 |
3rd May 2022 7:14am |
The leak is almost certainly from the oil cooler seal - it's such a common fail item it should be a service item. 2012 TDV8 Vogue (L322) |
3rd May 2022 7:35am |
Hopefully the new gasket part numbers indicates that the gasket material has been improved. |
3rd May 2022 8:31am |
Many thanks for answers! But does this mean there are more O-rings to replace in this area? I did replace the two on the one tube between firewall and oilfilter (behind oilfilter).
6th May 2022 6:43am |
You need to remove the oil cooler from the top of the engine to replace the main seal. Plenty of how-to’s on this if you use the search function. 2012 TDV8 Vogue (L322) |
6th May 2022 6:46am |
Thank you very much👍🇳🇴😊 |
6th May 2022 7:28am |
