Home > Maintenance & Mods (L322) > Upgrading from 2007MY to 2011MY - Seat differences / Exhaust
Page 2 of 3 <123>
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
Thank you all for your comments, it's very much appreciated.
In the end I decided to scrap the idea of the newer 5.0, largely because of the seats not being as comfortable and Timing Chain issue horror stories.
I'm now considering the vehicle below and would love to hear your views on this.
As I've had the Jaguar 4.4 V8 Petrol L322 for the last 8 years, I'm not very knowledgable on the diesel variants.
This is the exact same colour combo as my current car, but this has only covered 30,000 miles and comes with the 3.6 TDV8 engine.
I know the 4.4 diesel is a popular choice, but is the 3.6 really one to avoid?
I see Harry at Harry's Garage likes his, but what's the general consensus.
Once again, your knowledge and opinions are all greatly appreciated.
The link is here:
https://www.carnexions.com/vehicle/landrov...8300ff5454
Post #630416 2nd May 2022 5:03pm
garyRR
Ok so all I'd say is that I had a 3.6 TDV8 - plenty Powerful enough engine.
BUT, the 4.4 TDV8 is streets ahead of the 3.6 to the point I'd call it an entirely different car. The double glazing, the updated air suspension and active body control, the combination of the new engine and the new 8 speed ZF transmission... all makes for an entirely different car to the 3.6, which I consider better in pretty much every way... and as a bonus its slightly more economical.
The 3.6 was a good engine but a quick search on here will show the 4.4 TDV8 is the one to go for and is a very reliable engine. Can't remember the member but there's an owner on here with one that's done 340,000 miles.
If I were you, I'd spend the same money for a 4.4 TDV8 with higher miles than a 3.6 TDV8 with low miles. Usual things apply - you're looking for a vehicle with low owner's, full service history (don't expect full main dealer), 2 keys, the manual, good quality tyres on it, hoards of receipts and crucially, receipts to show the oil cooler seals have been done and the auxiliary belt has been done. If you find a car without that evidence, put the money in the bank and use them as a bargaining chip. 2015 Range Rover Autobiography 4.4 SDV8
Post #630425 2nd May 2022 5:54pm
aja500
That's good to know, thanks Gary.
Sounds like it's not just your own personal opinion either, but the general consensus, which is what I want to hear.
Thanks once again for taking the time to share your knowledge Thumbs Up Thumbs Up
Post #630427 2nd May 2022 5:58pm
aja500
Just two questions Gary (or anyone else who can answer these).
1. Do you know if cooling seats are standard on the 4.4 TDV8, as ideally I don't want them. From what I understand, the seats have slightly less padding, which I'd rather not have as this car is solely for journeys to Europe.
2. Would you say the 4.4 TDV8 is much quieter than the 3.6 TDV8, or there's not much in it?
Post #630429 2nd May 2022 6:06pm
garyRR
In answer to 1, the HSE, Vogue and Westminster do not have the cooled seats as standard but some do have them specified as an option. The Vogue SE (later replaced by the Autobiography) have the cooled seats as standard.
Easy way to tell is that cars without the cooled seats don't have the 2 seat control dials either side of the clock (will make the job easy when looking at photos and adverts online) and instead it's blank plastic. Both my Range Rovers have had cooled seats so I cannot compare to the regular heated only seats but... I wouldn't say they're uncomfortable and on a long journey, especially through sunnier European countries I would personally consider the cooled seats a must-have because they prevent a clammy back when doing a long journey.
Re quietness, yes, the 4.4 TDV8 can hardly ever be heard inside the cabin. The 3.6 has an especially noisy idle for whatever reason. The 4.4 is much quieter. The double glazing on the late cars reduces side noise significantly (drop the window and along the window edge and you'll see the 2 layers of glass).
Interestingly, I got my Sound meter out on my phone, placing it in exactly the same location inside a brand new 2021 Range Rover Sport and my 2011 Range Rover L322 and the 2011 was actually 2 decibels quieter at 70mph. The seats are also WAY more comfortable than in the Sport. Getting back in my L322 was like getting into a lounge. 2015 Range Rover Autobiography 4.4 SDV8
Post #630430 2nd May 2022 6:13pm
aja500
That's really interesting - Thanks once again Gary, seat comfort is a big thing, but then as you say, cooling will be a bonus, ultimately though, a quiet engine is probably the most important factor coming from a 2007 L322, 4.4 V8 Petrol.
Thanks again for taking the time to reply Thumbs Up Thumbs Up
Post #630432 2nd May 2022 6:18pm
garyRR
My old car was a 2007 3.6 TDV8 and honestly, as soon as you Step inside a 2011 or 12 car, you'll realise that whilst it looks almost the same on the outside, it is an entirely different beast. 2015 Range Rover Autobiography 4.4 SDV8
Post #630433 2nd May 2022 6:24pm
mjdronfield
Agree with the above. I had a small loan to get the 4.4 instead of the 3.6…. I came from a TD6.
Longest I’ve ever kept a car.
Indeed, the Vogue does not have cooled seats as standard.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #630434 2nd May 2022 6:26pm
aja500
Thanks Gary and mjdronfield - Back to the drawing board Thumbs Up Thumbs Up
Post #630436 2nd May 2022 6:33pm
mjdronfield
You prob need to drive a few, forgetting the seat… and make sure of the engine choice you want first…. Then look for one without cooled seats.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #630437 2nd May 2022 6:41pm
dhallworth
I’ve got a 2007 Supercharged and my Dad has a 2012 4.4 TDV8 Autobiography which has only covered 24k miles. He’s owned it since new and only ever used it for long trips.
There’s pro’s and con’s to both… the petrol is much smoother and almost inaudible at idle, the TDV8 has a slight low frequency drone. Drone is the wrong word as it sounds like it’s a bad thing, it’s not but it is noticeable.
The 4.4 in many ways feels quicker then the SC as it gives you a bucket load of torque low down. Over 30mpg is achievable on a run too as it’s doing 1600rpm at 70. 90 is still under 2000rpm too.
I agree with earlier posts, I’d rather have a higher mileage 4.4 then a lower mileage 3.6. Especially as it’s got the 8 speed box, that box is lovely. I don’t dislike the 6 speed in my car either though, but the 8 speed is the better box.
Low mileage cars tend to fetch huge premiums and usually haven’t had the common fixes done as the mileage increases. Buying one that’s had more use and has receipts for the common issues being sorted will be a good buy IMO.
If you really don’t want the cooled seats you’ll need to look for a Vogue. As I believe they were standard fit on the Vogue SE, Westminster and Autobiography. I’ve got the brochure here for the 2012MY so can dig out the specs if you’d like.
Agree with the comments above though, try one with cooled seats as there’s no way you can describe them as uncomfortable Smile
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #630438 2nd May 2022 6:42pm
Weegie
You can have a run in my 2008 3.6 tdv8 when we do the top box. Thumbs Up John
GAP iiD BT
Post #630440 2nd May 2022 6:57pm
aja500
Thanks David for such a detailed reply and I know what you mean about certain components being likely to fail at certain times, with a higher milage car hopefully having had these addressed. Thank you also for the comparison between yours and your dad's car, which is interesting to hear.
Thank you once again also to mjdronfield for your good points made.
I think you must be right about the seats and which models they came in as standard David, as Gary also suggested the same.
Maybe I do need to go and look at a few, looking at the engine and gearbox first, before fitting other elements around that.
Just quickly going back to the 5.0 option, aside from the timing chain issues, I drove one once a good few years ago and it just seemed to scream under acceleration, which I didn't like...... Although to be fair, I did drive it quite hard.
Has anyone any experience of this model, can it be driven gently and when done so, is it quiet? (I will be taking it steady with the dogs in the back).
Also, does anyone know if the timing chain issues have been done free of charge as a Land Rover recall?
Post #630441 2nd May 2022 7:00pm
aja500
That would be really useful, thanks John Thumbs Up Thumbs Up
Post #630442 2nd May 2022 7:00pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Just on the seats, I believe David is right and Gary is wrong. I’m pretty sure the Westminster had cooled seats as standard. The Westminster was the 2012 run out blend of vogue and vogue SE. I don’t believe there was an HSE spec with the 4.4.
Having recently joined the full fat club with a 2011 autobiography, I too would very much recommend the 4.4 over the 3.6 for all the reasons already given. I was fortunate to find a well maintained example at an independent who had looked after it for the last 8 years and was able to provide lots of history on it.
Post #630443 2nd May 2022 7:14pm
Page 2 of 3 <123>
