Home > Technical (L322) > Parking sensor light flashing and sensors not working
Archieatkins
2007 Range Rover Vogue TDV8 Java Black
Hi all
Is there a way to find a faulty parking sensor please? Mine have stopped working and the light on the centre console is flashing. I don’t have a GAP tool but is that the only way?
Post #630290 1st May 2022 2:57pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
With ignition on and the engine NOT running, engage R. Then try to listen to each one of the sensors. They emit a faint pulsating sound. The one or ones not doing so is/are either faulty or somehow disconnected from the circuit.
A chafed wire could be the culprit.
Post #630299 1st May 2022 4:29pm
bishbosh10
Have a search. There are a couple of quite detailed threads covering the parking sensors. However, plugging the old girl in has to be your first port of call, otherwise you'll be guessing even more than normal! Very Happy Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #630514 3rd May 2022 12:20pm
