Home > Technical (L322) > 4.4 TDV8 egr pipe into intake
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
4.4 TDV8 egr pipe into intake is there a gasket, when I was replacing my belts I noticed a large build up of gunk on the butterfly valve and the egr pipe so decided to clean it all up (what a mess) on refitting then now clean egr pipe into the throttle housing I noticed there was no gasket etc and it seemed a loose fit, I did put some liquid gasket on but should there have been a gasket there in the first place [/list] 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #630356 2nd May 2022 9:44am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
There should be an o ring that sits just inside the housing, no gasket. Thumbs Up
Post #630359 2nd May 2022 9:57am
Furnitureman
Thought so There was no o ring just gunk best sort it out 2012 Range Rover Westminster 4.4 TDV8
Post #630375 2nd May 2022 11:01am
Furnitureman
Any idea on part number or where to get one 2012 Range Rover Westminster 4.4 TDV8
Post #630377 2nd May 2022 11:06am
GraemeS
Australia
I didn't find one in mine but perhaps I didn't dig deep enough in the recess. However I recall that the pipe felt as though it was pushing through a seal.
Post #630464 2nd May 2022 10:11pm
diesel Dave
Not sure if this is your exact year ETC but if you look at the picture you can see where the O ring should fit. LR023038.
Post #630532 3rd May 2022 2:51pm
