Home > Technical (L322) > Removing “bong” notifications with gap tool |
2010BlackL322 Member Since: 30 Oct 2021 Location: London Posts: 119 |
All,
30th Apr 2022 10:27am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Why would you want to do that ? Is there a specific reason
30th Apr 2022 11:07am |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 589 |
If you are talking about that really annoying bong when you leave the keys in the ignition, then yes you can.
Thanks for the replies.
30th Apr 2022 11:24am |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Yes, it will be silent mode for warnings/faults(only messages on display) when you disable the "key in ignition" warning sound. If I remember correctly of course... |
1st May 2022 1:42pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 586 |
Yes, it is indeed possible to disable the bong sound for several types of warnings. If I remember correctly it's under the car configuration menu. I would advise against it though, perhaps with the sole exception of the "ice warning" on which I plead guilty as charged...
1st May 2022 3:39pm |
I wanted to disable the high mode, bong, when close to 30MPH, and the damn door is open bong, why, because filming etc, in and out of the vehicle, door open, it’s just plain annoying. I know the door is open! I don’t need a bong.
1st May 2022 6:53pm |
HV_Sparks Member Since: 03 Oct 2022 Location: North Yorkshire Posts: 7 |
Did you get this figured out in the CCF?
5th Feb 2023 8:54pm |
Floopy Member Since: 28 Jan 2023 Location: Chichester Posts: 81 |
I too would like to disable the "bong of doom" whilst awaiting a few sensors and bits to arrive. 2006 L322 Vogue SE 4.2 |
20th Feb 2023 10:56am |
