Home > In Car Electronics (L322) > CD Changer Problem
dan_uk_1984
CD Changer Problem
Today I had the CD Changer out to run the new cable for Intravee and the DAB unit. However since putting it all back together (Intravee won't turn up for a few days) the CD changer is stuck on the following screen:
07052011476 by d86cfv, on Flickr
However there are CD's in there, or even if I take them all out the message stays the same.
To attempt to resolve I have:
Pulled the CD Changer Fuse
Disconnected the Battery
Traced all the connections to ensure I've not left anything unplugged
Is the changer goosed? I may have unplugged it initially with the key in the ignition so possibly pulled its power while active.
When I insert the cartridge it checks every slot and then loads CD1 but just doesn't play or show the other CD's.
What say you collective knowledge?
Dan
Post #63002 7th May 2011 10:58pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Dan - You haven't left any intravee wiring in have you. I have the Intravee set up so can't use the CD anymore and my screen comes up with that first of all for a second or two and then recognises intravee and switches to iPod on the screen?
Maybe worth checking you have not plugged any of the intravee studd in "ready to go" for when stuff turns up? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #63015 8th May 2011 7:56am
dan_uk_1984
I've not got the intravee yet, I was just running the AI-Net cable to the rear of the car. I've left the changer unscrewed so I can pull it out easily enough when it does all come. But I've not changed the configuration of any of the wires.
I'm concerned that this may be part of a "bigger picture" and when my Intravee turns up that's not going to work now either from whatever I've done.
Post #63023 8th May 2011 10:24am
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Dan,
I've had a similar observation when my CD changer jammed... Would cycle through but say "no discs" etc etc. This means that the head unit gets the message that there is no output from the CD so goes back to radio or tape... I can't remember the name of the iPod link i fitted but I had to get the CD changer working. Not that difficult, especially as you've undone the securing bolts, pull it out, take the little screws out, then cover off. You can then see where the cartridge moves to collect discs from the mag, i used a little bit of dry silicon lube, gentle bit of teasing while powered up and voila! Now I'm just careful to keep an eye on the track number of the CD while I listen to my iPod so it doesn't get to the end and go for another disc.
Post #63026 8th May 2011 11:20am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hey Dan.
Odd that it seems to check for the CD's- wonder if when it was unplugged whilst powered if the carriage wasn't "parked"?
If the cd loads but won't play often on laptops it's that the laser isn't right at the centre and so can't read the disc lead in/header.
Sadly though to check this would be a case apart job I guess.
Post #63027 8th May 2011 11:23am
dan_uk_1984
Thanks guys.
What's odd is that the system doesn't revert to Radio, it just sits there on CD1-01. Like it thinks its playing.
I don't understand how it can go through the check CD process loading them all and spinning them all for its check and then go back to saying no disk 2-5 and then just sits on CD1-01. Even if I take the mag out it says CD1-01.
I believe the 3 pin is the data cable, and the 6 pin is the signal cable. If I unplug the data cable the CD disappears from the menu so I only get radio & tape. If I plug it back in it goes through its loading sequence, comes up on the display but still only has CD1-01.
Even though as of Tuesday I wont be using the changer, this has really bugged me. To the extent I'm searching fleabay for a new unit.
Post #63028 8th May 2011 11:41am
dan_uk_1984
Sorted.
Bizarrely it was the roof switch for the Rear Seat Ent' I don't know what made me press it, but when I did the CD started whirring away and Britney started once again (don't get me wrong, I hate her, but her latest album is very good Embarassed - Anyway, I digress)
I've never noticed it before, but then I don't use the RSE other than in the first week of ownership!
Bring on DAB Radio on Tuesday!
Post #63032 8th May 2011 1:26pm
Stephen.125
Glad it's sorted Thumbs Up
I'm not touching the Britney comment. Wink
Post #63035 8th May 2011 2:24pm
dan_uk_1984
Believe me, I'm ashamed.
Post #63037 8th May 2011 2:38pm
daveo
hi my one does that dan, if i push the roof button the rear screens turn on and it will lose the cd changer. V8 facelift Range Rover Autobiography 22" wheels.
Post #63041 8th May 2011 4:29pm
dan_uk_1984
Genious bit of LR bodging!
Post #63044 8th May 2011 5:15pm
SteveMFr
Site Sponsor
Ha. Remember the all too common P38 lock motor problem? When you opened the front door with the key, you still couldn't get into the rear hatch on a LHD car - because the RH front door lock has a microswitch that activates power to the rear hatch button. For you guys not a problem, for us LHD people, tho...
Try explaining that to someone: well my power door locks are on the blink and I have to unlock the passenger door to open the rear Embarassed
At least that hasn't changed. These cars still make great conversation topics.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #63047 8th May 2011 5:47pm
M44K TS
^ Makes Baby Jesus cry Crying or Very sad 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #63049 8th May 2011 6:08pm
dan_uk_1984
Seriously it's not that bad Embarassed It's a bit retro 90's.
Just wondering if I can dig myself out of this...
Post #63050 8th May 2011 6:16pm
M44K TS
Nope. Laughing 2006 Mercedes CLS
Post #63051 8th May 2011 6:16pm
