Home > Technical (L322) > The saga continues... now gearbox issues maybe...? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
Be careful resetting the gearbox adaptions - it can cause problems with the gearbox.
24th Apr 2022 11:31pm |
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 |
Thanks David! I read that this evening too when I got home, after I had done it!! Aarrgh! I will be gentle from now on! I've probably broken it more now! I wont reset them again! |
24th Apr 2022 11:36pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
First call would be either a gearbox oil & filter change or a mega flush on the gearbox unless there’s any proof of servicing?
25th Apr 2022 6:18am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3196 |
An automatic gearbox specialist will be able to diagnose the fault. Don't blow money on an oil and filter change just yet least of all a megaflush. How many miles has it got and is it on standard size tyres/wheels? 2012 TDV8 Vogue (L322) |
25th Apr 2022 9:51am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Firstly, from my research dhallworth seems to be spot on about resetting the adaptations, so do treat the cat gently for now.
25th Apr 2022 10:42am |
Thanks chaps.
25th Apr 2022 12:01pm |
A larger diameter tyre than stock is essentially a higher final drive ratio so the gearbox ecu may just be sensing more load and deciding it shouldn't change up a gear. I run these on mine and I've often wondered if it contributes to it holding gears longer than it should going up hills but it's fine on the flat. I run mine 33 front and 36 rear. 2012 TDV8 Vogue (L322) |
25th Apr 2022 12:10pm |
Oh, and I get the message about the adaptations. I wrongly thought it was a 'car learns driving style thing' I only read RRPhils posts about what the box is really learning when I got home after I had done it so will take it easy on the drive. |
25th Apr 2022 12:11pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
As you say, 255x50x20 are the standard. For your model year. I,and others, have fitted 255x55x20 with no problems. I have found the most comfortable pressures are 33 psi front and 36 psi rear. Jaygee beat me to it 😊
25th Apr 2022 12:14pm |
That's useful info Weegie and Jay. Thanks.
25th Apr 2022 12:18pm |
I just logged into the RR Sport forum and noticed this post at the top of the page:
25th Apr 2022 2:28pm |
Thanks David. Yes, very similar indeed. That one was hanging in third, mines 4th, but other than that, very similar symptoms.
25th Apr 2022 7:28pm |
Honestly you best bet is to get it booked into an auto gearbox specialist. A diagnosis won’t be much and it probably needs a service anyway. Also get the fluid in the diff’s and transfer box done at the same time. 2012 TDV8 Vogue (L322) |
25th Apr 2022 7:56pm |
Thanks Jay. Just trying to get an idea of whats going on before I spend more money on this thing! At this rate it will get shut up in the shed where I cant see it and can forget about it! |
26th Apr 2022 8:00am |
