Home > Maintenance & Mods (L322) > 2011-12 Brake Disc Shield replacement
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Does anybody know if you can replace a Brake Disk Shield without taking the Hub off ? I have seen some Brake Disc Shields on the Internet that have a section out, but these are not for the Brembo Brake 4.4 TDV8’s.
Are there any instructions for replacements, I could not find them in search.
Many thanks -------------------------------------
MY 2012 4.4 TDV8
Post #629583 24th Apr 2022 9:25am
dhallworth
I’ve just done mine on a 2007 4.2 and I *think* they’re the same on the 4.4 TDV8.
Unfortunately they sit behind the flange that the brake disc sits on so the only way you’ll be able to replace the dust shield is by removing the flange which means pressing it out of the wheel bearing.
This is guaranteed to knacker the wheel bearing so you’ll need to replace this too.
Post #629585 24th Apr 2022 9:58am
bwelton
Just found a YouTube showing it being replaced with a Disc Shield, that does not completely encircle the Hub, but I need to find if this version is available for those with the big Brembo Brakes.
MY 2012 4.4 TDV8
Post #629586 24th Apr 2022 10:01am
dingg1
I think I may have worked offshore with that bloke, 😂😂😂😂 just threw copper slip over the top of every bolt head and hoped it was going to do something.
Woeful
Post #629587 24th Apr 2022 10:12am
mjdronfield
Did mine before Christmas. Bought a new shield from LR. Just cut the thin bit of steel off and slide it behind the hub…. No need to touch the hub.
You will have to cut the old one off. Up to you if you want to put washers on to help it down the line.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #629595 24th Apr 2022 12:23pm
