![]() | Home > Maintenance & Mods (L322) > 2011-12 Brake Disc Shield replacement |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 ![]() ![]() ![]() |
Does anybody know if you can replace a Brake Disk Shield without taking the Hub off ? I have seen some Brake Disc Shields on the Internet that have a section out, but these are not for the Brembo Brake 4.4 TDV8’s.
Just found a YouTube showing it being replaced with a Disc Shield, that does not completely encircle the Hub, but I need to find if this version is available for those with the big Brembo Brakes.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1354 ![]() ![]() |
I think I may have worked offshore with that bloke, 😂😂😂😂 just threw copper slip over the top of every bolt head and hoped it was going to do something.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7868 ![]() ![]() ![]() |
Did mine before Christmas. Bought a new shield from LR. Just cut the thin bit of steel off and slide it behind the hub…. No need to touch the hub.
