![]() | Home > Maintenance & Mods (L322) > 2007 MY Deployable Side Steps |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
David, you need to cut the sound deadening material then double sided sticky tape the ECU to the inside of the panel next to the drivers left knee |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
That’s where I thought it went Craig. Certainly where it is on the steps we fitted to our 2012.
I wonder if that's a revision David? On every 07> I ever fitted, the ECU went into the same place as your father's 12MY... I wouldn't think the wiring would have been long enough to have fitted the ECU there??? |
Thanks Craig.
