Home > Maintenance & Mods (L322) > TDV8 Turbo replacement |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 454 |
Driver side turbo (UK) is doable from Beneath the car although access is tight and they’re not for the faint hearted!
22nd Apr 2022 12:09pm |
Sleepy Jen Member Since: 15 Feb 2021 Location: Basingstoke Posts: 32 |
Thanks, this would be my first turbo on a TDV8, I have done a few on VW/Audi cars which although not always easy are simple in comparison to this. Time is on my side, so one to deliberate over for a while. |
22nd Apr 2022 12:41pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
It’s a horrible job, I’m handy with the spanners and used to be a LR/JAG tech and when my turbos went- i didn’t contemplate doing it myself for very long when I saw what was involved- engine out is really the best way as it is so tight as has been said 2009 (2010 MY) 5.0 Supercharged Autobiography
22nd Apr 2022 4:47pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1747 |
Drop the subframe off, then diff off. It's not an engine out job...
22nd Apr 2022 6:11pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
My local Indy quoted £1,000 to replace the O/S turbo. They said it was the actuator but I can’t find anyone who can advise if it’s possible to replace just that and not the entire turbo. Got - 2017 SDV8 Autobiography in Loire Blue
22nd Apr 2022 7:58pm |
Thanks everyone.
23rd Apr 2022 4:47pm |
Unless the price of turbos have gone up recently, that's a little steep
23rd Apr 2022 8:53pm |
That’s a lot! Aj Land Rover in Alton did both mine with brand new turbos for just over £3k a year or so back 2009 (2010 MY) 5.0 Supercharged Autobiography
23rd Apr 2022 9:11pm |
If you have the time and doing them yourself you could chance the actuator if you can source one, but they’re not cheap!
24th Apr 2022 9:22am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
There has never been a need to do idling before shut down on turbo's since the days a long time ago when they didn't have water cooling and were run on mineral multigrade oils. The main thing for turbo life is not to work them hard before the engine is up to operating temperature (oil not water) and change the oil regularly and use the recommended spec. 2012 TDV8 Vogue (L322) |
24th Apr 2022 5:17pm |
Thanks TDV8 Paul, I had not heard of AJ Land Rover Before. I have just had a look at their website, and obviously you were happy with their work - so I will give them a call. |
24th Apr 2022 6:23pm |
I got a quote from AJ land Rovers this morning - £5700, so both (Keith Gott) are similar. |
25th Apr 2022 8:47am |
That’s interesting, price has changed a bit! Probably their reputation has grown as they looked fairly new looking at the workshop when mine was there. I thought they were good, kept me updated and sent me videos of my car and what they found. They also refuse to fit anything other than new stuff so that initially filled me with confidence 2009 (2010 MY) 5.0 Supercharged Autobiography
25th Apr 2022 10:08am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 804 |
I wonder how "Best Turbos" do this without taking the engine out ??
19th Jul 2024 6:02pm |
