Home > Maintenance & Mods (L322) > Windscreen Wiper mechanism LR035813
topgeartowers
Hi all,
My 2012 Westminster needs a replacement windscreen wiper mechanism (LR035813). It's on backorder everywhere, and lots of posts on here from people as far back as 7 years trying to find one!
I've read online that the linkage and motor are welded together, so you can't buy in parts, but I'm wondering if anyone on here knows for sure?
I'm thinking could I buy the motor (which I think is model no. 67638360603; https://www.autodoc.co.uk/ridex/12746812 )
and then connect it to a linkage like this:
https://www.ebay.co.uk/itm/164976038554?mk...media=COPY
The other option is buying from salvage, but I'm back into not knowing how long the motor will hold out.
I saw another post saying you can change the motor in situ, rather than removing and replacing the whole linkage - has anyone done this who could advise how it went?
Thanks all!
Post #696302 16th Jul 2024 12:09pm
kevinp
Is it the ball joints that are worn and keep popping off?
Sure I've seen some repair clips if that's the case.
Post #696306 16th Jul 2024 2:08pm
topgeartowers
Don’t know to be honest. Wipers started parking randomly, occasionally going mad and not stopping, then also not working at all. Though sometimes they work fine for a while. It’s under LR extended warranty, so sent it in and they said the part I need is on back order. They’ve had the car for 5 months, so I’ve given up waiting. I asked the part number and they sent me the above.
Post #696321 16th Jul 2024 5:06pm
kevinp
5 MONTHS !!!!!!
Rediculous.
Post #696331 16th Jul 2024 6:53pm
mjdronfield
I don’t think they are welded together, just that you might have to order as a unit.
Had a new motor on mine a few years ago and the linkage was not changed as the garage couldn’t get the wiper arms off.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #696333 16th Jul 2024 7:57pm
mjdronfield
Not sure if this pic helps….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #696338 16th Jul 2024 8:09pm
topgeartowers
No, that picture is terrifying.
What I'm hoping is that I could buy a new motor and replace in situ - has anyone done that themselves?
Post #696368 17th Jul 2024 10:22am
mjdronfield
🤣 I just wanted to show the possible mounting points to the linkage, not all the innards but it was the only pic I had….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #696371 17th Jul 2024 11:17am
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #696372 17th Jul 2024 11:22am
topgeartowers
This is amazing! Thank you so much.
It certainly seems like I can swap the motor over. Has anyone got experience of doing that?
Post #696376 17th Jul 2024 12:02pm
