Home > Technical (L322) > oil in the intercooler
pablo
Ireland 2012 Range Rover Westminster TDV8 Fuji White
i have a lot of oil in the intercooler my mechanic says its the turbo seals but another person said its not its too much presure in the engine....... please can anyone help
Post #628994 18th Apr 2022 4:48pm
JayGee
How are you measuring the oil quantity - have you removed the IC and drained it?
Do you have high oil consumption? All turbo cars push some oil through the IC btw. High positive crankcase pressure due to blocked breather can force more oil from the turbo seals as the oil drain gets pressurised but never heard of this on these engines. 2012 TDV8 Vogue (L322)
Post #629007 18th Apr 2022 7:40pm
pablo
i dont have high oil consumption, so is there a drain on each of the turbos
Post #629012 18th Apr 2022 8:11pm
pablo
when you say blocked breather, where is that on the engine?
Post #629013 18th Apr 2022 8:15pm
JayGee
Each turbo has an oil drain to the sump. No idea what the PCV system looks like on these engines. 2012 TDV8 Vogue (L322)
Post #629023 18th Apr 2022 8:53pm
