Home > Maintenance & Mods (L405) > Upgrade / Swap HVAC unit
RutlandBoy
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Hi All,
Not sure if this should be in this part of the forum or 'What did you do in your...." part but it is a modification so I placed it here !!!
I know this has been done perhaps 100's of times before but I've just updated (upgraded ?) the HVAC unit in my 2015 Vogues SE to the (Slightly) later HVAC unit to allow the heated seats to work without using the screen.
It was one thing that slightly disappointed me on a 2015 vs the later 2016 model.
After some investigation got the unit from an eBay salvage supplier for £80 which I thought wasn't too bad.
I might be wrong but I think the key thing I learned whilst researching was to get the part number beginning with a G not the D of the original.
Anyway here are some pics of the swap.
Good condition as received from the salvage seller on eBay
This is the new HVAC note the part number starting with a G not a D
I didn't bother taking a picture of removing the trim surround at the sides or the top you know how to do this I'm sure - if not there are some videos on youtube - I was a bit worried about this and the sides were a little stiff - but came away nicely - the top was easier - I started at the right and then gently prised it away. I then removed the trim clips (some came out with the panel) and put them back in the right place in the dash.
Next was the removal of the frame for the display so you can get at the four torx screws actually holding the HVAC unit in, accomplished by removing four torx screws and then gently removing the trim panel for the HVAC unit.
Store both safely (and away from each other so they don't get scratched !)
Then remove the 4 torx screws from the HVAC unit and gently move forward - there is plenty of cable to allow the unit to be pulled forward, then simply unclip the single connector
I didn't take any photos of this as you know how these things work !
Swap to the new unit (don't get them confused!!) the easy way to check is that in the new unit the two outer dials can be pressed (they have a switch in them!) the old one doesn't.
The refitting is simple the reverse of the removal. -
replace 4 torx screws in the HVAC unit
rrefit the HVAC trim panel (make sure it clicks into place propsely)
Put the frame for the display back in using 4 torx screws (it only goes one way with the bigger tabs at the top otherwise is doesn't sit correctly!)
replace the top display trim panel - taking care to align the clips correctly - and ensuring that the all the clips (especially at the top and bottom of the display are fully home)
replace the two side trims
And then test the unit.
Don't do as I did and panic slightly when testing the unit, without the car started the HVAC comes on fine and will work, but pressing the two outer dials will have no effect (panic!!) - but then I remembered a post I saw that said that they only worked when the car was started - started the car and hey presto - working as two picture below
overall time to complete was 40 minutes in the sunshine
I know its a simple modification but it makes the usability of the already wonderful car even better for me !!
Now - considering upgrading the display - but I quite like the dual TV (you know passenger watching TV whilst driver can see sat nav etc) and I'd loose this I think - such a shame.
Happy Easter everyone !! L405 4.4 V8 Vogue SE Santorini Black
RRS L390 4.2 S/C Stornoway Grey
Classic Range Rover Overfinch 5.7 - their first prototype - under restoration
Late Range Rover P38
Range Rover 3.9 Classic Softdash
Range Rover Classic Overfinch 5.7 - Sadly gone
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #628775 16th Apr 2022 10:13am
Martyg
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Great stuff. It's something I'd love to do so must keep a look out on eBay for a panel. Thanks for posting
all the info.
Post #628861 17th Apr 2022 10:03am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
Re: Upgrade / Swap HVAC unit
I had no idea this changed later and it's something I'll have to seriously consider as I really miss the simple buttons of my previous car. Stabbing at a touch screen is much more difficult than pressing a physical switch.
Do you know if the final two letters, 'DG' in the case of your new unit, are of any significance?
Also, are the switches in the knobs tactile so a seller could confirm they are the version with switches?
Thanks Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #628914 17th Apr 2022 7:38pm
RutlandBoy
Hi MrWold,
Your first question "
Quote:
Do you know if the final two letters, 'DG' in the case of your new unit, are of any significance?"
I have no idea I'm afraid! - all I know is that my 'old' unit has the same DG on the label - and the part number is exactly the same other than the first letter changing from a D to G on the new unit - Sorry I can't be of more help !
This is my old unit (below) and as you can see the only difference is the first letter, everything else is the same.
The second question is easier - Yes there is a definite difference between the two - the new one has a definite 'switch' feel to it - it moves 'in' when you press it - my old one doesn't - so a seller should be able to tell you that I would think, no switch and it's not suitable
For full disclosure - I scanned my car this morning with my IID scanner and I noticed an error code on the HVAC unit - which was 'invalid switch combination' - no other errors and everything works correctly on the HVAC unit (I tested everything this morning!!) and so I guess it means that the car doesn't recognise the panel correctly - but it has no effect on its operation - It might be possible to change the CCF to eliminate the error but I'm really not that bothered - I will keep an eye on it, I will keep my old unit to swap back just in case.!!
It worked immediately with no programming - just swap and go.
For me look and the convenience is worth it !!
If anyone knows if this is fixable I'd love to know - I might ask GAP to see if its something that can be changed in the CCF but my thinking is that it might not be.
I'm not sure if my unit came from a sport or a range rover perhaps that might explain the error - but the unit number is the same for both so I don't think that's the cause, its just that my car isn't meant to have it (obviously!!)
From my limited research on the net - other unit part numbers might work - but the key thing is the press 'switch' capability - no switch action then definitely won't work !!!
Obviously it your choice and risk but fro me it was worth it - relatively easy to do and for me a good modifcation. L405 4.4 V8 Vogue SE Santorini Black
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #628926 17th Apr 2022 10:36pm
MrWold
Thanks RutlandBoy as I cross-posted. Very useful.
Answering my own question here but it looks like the 'CC' suffix is always missing the seat button and belongs to the Sport. An HPLA-18A802-CC pictured:
That leaves the 'DC' vs the 'DG'. Anyone know? Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #628927 17th Apr 2022 10:36pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I have another of these seat control HVAC units in very good condition for sale. PM me
Mine is the version you press in the dial (like a button) to activate the seat heating/cooling. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #629109 19th Apr 2022 4:40pm
knwatkins
Definitely a worthwhile upgrade. I did mine back in Nov 2020. More info on part numbers in this thread: https://www.fullfatrr.com/forum/topic57475.html Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #629113 19th Apr 2022 4:53pm
RutlandBoy
Hi knwatkins
Do you have a scanner ? if so does yours throw and error like mine does ? (Invalid switch combination)
If not I'm puzzled by my error !!! (or of course how did you fix it !!)
Thanks
Chris L405 4.4 V8 Vogue SE Santorini Black
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #629119 19th Apr 2022 5:12pm
knwatkins
Hi Chris, yeah the code is normal when you replace the panel so don't fret. It doesn't affect anything. In all honesty, I haven't tried to code it out with the IID tool but I've taken the 'if it ain't broke don't fix it' approach. Kev
Post #629121 19th Apr 2022 5:16pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I’ve completed this upgrade also (on an MY15) & get the same code when scanning with the iid - although as you say, everything functions ok.
Post #629122 19th Apr 2022 5:18pm
RutlandBoy
Hi Kev,
That is exactly my approach Rolling with laughter
Just interested I guess, but good to know Thumbs Up
Thanks L405 4.4 V8 Vogue SE Santorini Black
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #629123 19th Apr 2022 5:18pm
MrWold
I've just picked up a GPLA....DH on a certain auction site so fingers crossed that that suffix is OK. There are several reports on forums across the pond that it works.
Edited 2024 to say it worked fine and still is. Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #629126 19th Apr 2022 5:27pm
pierre_l
Switzerland 2014 Range Rover Autobiography SDV8 Santorini Black
I am trying to do this modification but only see hpla or cpla for sale? Any idea whether this works?
Post #693226 24th May 2024 6:04am
MrWold
I have a note on my car spready from when i was looking that HPLA is a different CAN bus speed and will not work. I wouldn't have known that my self so probably found it on the forum somewhere.
CPLA - no idea. Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #693227 24th May 2024 6:37am
