Home > Maintenance & Mods (L322) > 2011 4.4 TDV8 Alternator charge volts ? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2266 |
I had an alternator start to fail at about 120k so replaced the lot all pulleys water pump and alternator in one go been good as gold for last 100k agree with the others well worth doing if you have it stripped down |
27th Jan 2022 2:59am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Yes it is. If you’ve already stripped the engine for belts and pulleys etc, then the removal of this pump is very easy. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
27th Jan 2022 6:50am |
Ttrees Member Since: 08 Jan 2022 Location: Lincolnshire Posts: 13 |
Ok so there seems to be a small amount of play in the old water pump did your old one have any movement in the bearings? Its looking like i might have to get one ordered |
30th Jan 2022 10:38am |
Mine had no play at all iirc. I’ll check a little later and will confirm… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
30th Jan 2022 12:51pm |
Update
16th Apr 2022 8:00am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
The system for AGM charging is not a constant voltage. It only supplies max volts when needed and if the battery is charged and there is low load it will deliver less. 2012 TDV8 Vogue (L322) |
16th Apr 2022 8:03am |
Yes but the battery ony had 12.4v before starting and was dropping to 12.2 and as low as 11.9 with the lights on which is what my old alt was doing?
16th Apr 2022 8:08am |
12.4v before start is normal 2012 TDV8 Vogue (L322) |
16th Apr 2022 8:11am |
I got myself an Icarsoft LRV3 code reader and was trying it out yesterday when i noticed on the live readings the voltage.
16th Apr 2022 8:29am |
