Home > Technical (L322) > Yellow Speedo Marker
Mikeerhymes
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Hi All,
Any idea what the yellow marker is? I’ve searched around but can’t find anything, it’s just randomly appeared!
Cheers
Post #628475 12th Apr 2022 6:37pm
Baltic Blue
Speed Warning,
Select in menu, then adjust to whatever speed you want it to alert you.
Post #628477 12th Apr 2022 6:57pm
Mikeerhymes
Awesome, thanks Mike 👍
Post #628478 12th Apr 2022 7:20pm
bishbosh10
I think your warning was a little optimistic Laughing Laughing Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #628624 13th Apr 2022 8:13pm
mjdronfield
🤣🤣 I read somewhere that the unrestricted top speed of the 4.4TDV8 was 147mph. Might not want to weave about though… 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #628626 13th Apr 2022 8:19pm
garyRR
By default, it's set at 155mph. One can dream of getting somewhere quickly, instead our British motorways have Victorian speed limits, which seem absolutely mad off peak at 5am in the morning. 2015 Range Rover Autobiography 4.4 SDV8
Post #628683 14th Apr 2022 6:13pm
JayGee
The L322 should have lower speed limits than 'ORDINARY' cars they take longer to stop in an emergency, can't manoeuvre as quickly or as safely in an emergency and use disproportionately more fuel at normal M-Way speeds - I'll get my coat.... 2012 TDV8 Vogue (L322)
Post #628685 14th Apr 2022 6:27pm
garyRR
Yes please do. Laughing
Range Rover know their customer... otherwise they wouldn't be fitting Brembo brakes and tasty V8s!
I also really like "the Range Rover look", where each RR driver is compelled to turn and check out the RR passing them. 2015 Range Rover Autobiography 4.4 SDV8
Post #628686 14th Apr 2022 6:37pm
Baltic Blue
Mikeehymes,
You will find plenty of helpful? comedians on this forum Rolling with laughter
Spot the other difference between your speedo and mine and you will get a few helpful replies Thumbs Up
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #628687 14th Apr 2022 6:43pm
JayGee
My speedo hasn't gone above 65mph in 2 weeks Shocked
My (Real) MPG hasn't dropped below 33mpg in the same time either. Cool
Only in an L322 can you take longer to get somewhere but arrive like the journey is over too soon. 2012 TDV8 Vogue (L322)
Post #628688 14th Apr 2022 6:52pm
garyRR
Baltic Blue wrote:
Mikeehymes,
Mike
Mike, in case you're wondering, its the mph numerical readout. Very useful, especially in speed camera areas. 2015 Range Rover Autobiography 4.4 SDV8
Post #628708 15th Apr 2022 9:09am
