![]() | Home > Technical (L322) > Yellow Speedo Marker |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3803 ![]() ![]() ![]() |
Speed Warning, Select in menu, then adjust to whatever speed you want it to alert you. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 28 ![]() ![]() ![]() |
Awesome, thanks Mike 👍 |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I think your warning was a little optimistic |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
🤣🤣 I read somewhere that the unrestricted top speed of the 4.4TDV8 was 147mph. Might not want to weave about though… 2011 Range Rover Vogue SE 4.4 TDV8
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
By default, it's set at 155mph. One can dream of getting somewhere quickly, instead our British motorways have Victorian speed limits, which seem absolutely mad off peak at 5am in the morning. 2015 Range Rover Autobiography 4.4 SDV8 |
The L322 should have lower speed limits than 'ORDINARY' cars they take longer to stop in an emergency, can't manoeuvre as quickly or as safely in an emergency and use disproportionately more fuel at normal M-Way speeds - I'll get my coat.... 2012 TDV8 Vogue (L322) |
Yes please do. |
Mikeehymes,
My speedo hasn't gone above 65mph in 2 weeks |
Mike, in case you're wondering, its the mph numerical readout. Very useful, especially in speed camera areas. 2015 Range Rover Autobiography 4.4 SDV8 |
