![]() | Home > Maintenance & Mods (L322) > 4.4 TDv8 coolant leak- plastic connection? |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1260 ![]() ![]() ![]() |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 38 ![]() ![]() ![]() |
Hi Kevin, mind sharing where you purchased your hose from? My car been stationary a whole month waiting for the part, no stock in SA and waiting for import from UK might take another month through LR. 2011 Vogue SE 4.4 TDV8 |
Hi Deejay,
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
when you fit those hoses, you leave the clip in the closed position, and coat the surfaces with a small amount of Vaseline, and slide them on, and wait for the click. without the vasalene, they sometimes don't fully seat... -mine didn't, and the next day, it popped off! (this was on a different fatty, but same principle.) |
Olaftheviking Member Since: 21 Mar 2023 Location: Surrey Posts: 7 ![]() ![]() ![]() |
Anyone know of stock for this part (LR022661) my garage (More 4x4 Kingsley) tell me LR have them on back order but that could take a long time? Need a new one (they won’t fit second hand parts) to be fitted asap…. |
Depending on what part has broken it can also be repaired like I had to.
Thanks for the tip. I found the part with Nene Overland Peterborough this morning - it has been sitting on a shelf since 2018 so hope it's OK when it arrives. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
A lubricant works wonders when refitting hoses, especially in tight places. However, Vaseline can degrade rubber, so best to raid the bedroom drawer for some water-based or silicone based lubricant to line the hose fittings with. 2015 Range Rover Autobiography 4.4 SDV8 |
