Home > Technical (L322) > Voltage at the the rear loadspace fuse box
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
All,
Question for you, I have a Redarc manager 30 BMS hooked up on my dual battery system, I have tapped into the live feed from the battery to the rear fuse board, the BMS only sees 10.V when the vehicle is turned off, and only 11.5V when the vehicle is running.
For the life of me it makes no sense why the BMS shows a reduced voltage to that board. I have put a volt metre on the terminal, 12.4v, battery voltage, and 14.4v when the vehicle is on.
the BMS requires a IGN trigger, and I have piggy backed a fuse into the trailer fuse at the back, should my piggy back fuse be 15 amps, same as the fuse in the board, I have 5 amp in there now, just as a test. But surely, that would still trigger 12V on ignition.
All other charging inputs work fine, Solar and shore power etc, even my portable power bank charges the house battery fine.
Would a bad earth somewhere in my connections cause this?
Thoughts please, perplexed. Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #628454 12th Apr 2022 2:35pm
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
If I follow what you are saying correctly;
Then it would suggest the unit is faulty? 2010 3.6 TDV8
Post #628569 13th Apr 2022 11:30am
