Home > Technical (L322) > Paint for front grille 2003 |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi the paint code is under the bonnet on a plate . it is norm 3 numbers the handels should be the same colour coded with the car . paint code for epsom green is lrc 961 if this is the car you still have . prep for the grill and handels . i would scotch brite for a key then panel wipe . use a self etch or a plasto primer i would use plasto my self it is clear it has a very strong smell so mask up make sure you do the edges as well and then on with the base coat colour just a nuff to cover and do not over do it you are not looking for a high build on plastic then with in 20 min of putting base on get a clear coat of lacquer let that go for 5 min and put a second coat build it up to a high gloss leave dry overnight . if you take a colour match from the car and take it to a paint shop they will scan it and should give you the right shade of the base coat and mix it and put it in a spray can for you . that is if you do not have any spraying gear . new vehicle purchase
12th Apr 2022 8:37am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Trim paint codes aren't identified on the car.
12th Apr 2022 9:21am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7809 |
Didn’t someone find a Mercedes colour that was pretty close, or was that the silver grey on the inside trim panels?
12th Apr 2022 9:58am |
to save messing with paint go on to powerfuluk . com and buy the grill and door handle covers with the right colour format as pawl has explained or take the old grill to a paint shop and get it matched. new vehicle purchase
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
12th Apr 2022 10:33am |
That's probably the post I got my info from originally Paul,
12th Apr 2022 11:43am |
francy Member Since: 30 Jul 2012 Location: northwest Posts: 73 |
hi PM PANELS WARRINGTON will make paint for grill |
12th Apr 2022 7:39pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8249 |
Brunel is the colour of the later, post 2006 fatties...
13th Apr 2022 9:32am |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
Thanks Haylands will give that a go as the handles need doing as well as the grille L322 TD6 2003
14th Apr 2022 2:02pm |
