Home > Technical (L322) > Paint for front grille 2003 |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi the paint code is under the bonnet on a plate . it is norm 3 numbers the handels should be the same colour coded with the car . paint code for epsom green is lrc 961 if this is the car you still have . prep for the grill and handels . i would scotch brite for a key then panel wipe . use a self etch or a plasto primer i would use plasto my self it is clear it has a very strong smell so mask up make sure you do the edges as well and then on with the base coat colour just a nuff to cover and do not over do it you are not looking for a high build on plastic then with in 20 min of putting base on get a clear coat of lacquer let that go for 5 min and put a second coat build it up to a high gloss leave dry overnight . if you take a colour match from the car and take it to a paint shop they will scan it and should give you the right shade of the base coat and mix it and put it in a spray can for you . that is if you do not have any spraying gear . new vehicle purchase
12th Apr 2022 8:37am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Trim paint codes aren't identified on the car.
12th Apr 2022 9:21am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
Didn’t someone find a Mercedes colour that was pretty close, or was that the silver grey on the inside trim panels?
12th Apr 2022 9:58am |
to save messing with paint go on to powerfuluk . com and buy the grill and door handle covers with the right colour format as pawl has explained or take the old grill to a paint shop and get it matched. new vehicle purchase
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
12th Apr 2022 10:33am |
That's probably the post I got my info from originally Paul,
12th Apr 2022 11:43am |
francy Member Since: 30 Jul 2012 Location: northwest Posts: 75 |
hi PM PANELS WARRINGTON will make paint for grill |
12th Apr 2022 7:39pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8255 |
Brunel is the colour of the later, post 2006 fatties...
Some pictures at the end of this thread.... https://www.fullfatrr.com/forum/topic27260-30.html Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
13th Apr 2022 9:32am |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
Thanks Haylands will give that a go as the handles need doing as well as the grille L322 TD6 2003
14th Apr 2022 2:02pm |
