Home > Maintenance & Mods (L405) > wrong fuel
splud
Australia 2005 Range Rover HSE 4.4 V8 Nara Bronze
wrong fuel
So I just filled the diesel tank with unleaded! I know stupid - saw yellow cap and went for the yellow fill nozzle at station (which is unleaded)
But, cant find the tool to deactivate the inline wrong fuel thing. Plus does anyone know how to drain the fuel out? It's a full tank too!!
Thanks
Mr Stupid.
Post #628138 9th Apr 2022 6:52am
Mr Tee
Get a long screwdriver down the filler neck and move the wrong fuel thing back to its resting place , shine a torch down, its dead easy . The tool is normally in the boot, rhs stuck in the foam beside the spare wheel. If you have one, watch out as they easily break when you turn them.
Post #628142 9th Apr 2022 7:05am
splud
Thanks, I was ment to post in the L405 forum as I got a new/ 2nd hand one.
Post #628143 9th Apr 2022 7:09am
I think the secret is not to start the car so the (wrong) fuel gets pumped around the system, which will be VERY expensive to fix. There are a few companies who can come to you on the forecourt and suck it out with the minimum of damage.
Good luck 007 Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #628145 9th Apr 2022 7:36am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Sorry, I did not see this sooner as I might have been a help, A mate did the same a few weeks back and I took all my jerry cans to the servo and with an old electric fuel pump and a bit of hose drained his tank. Although not recommended there seems a view that 5% petrol in diesel won't do any harm. We put 10 litres of diesel in the empty tank and drained that before filled with diesel. The car started and ran with zero issues.
https://www.wrongfuelrescue.com.au/ 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #628148 9th Apr 2022 7:52am
splud
Many thanks, I did drive it only for 5kms, however it did start coughing. I'll try emptying the tank and putting some diesel in it and empty again. Thanks everyone. Smile
Post #628154 9th Apr 2022 9:13am
Probably a silly question but your car description says you have a 2005 4.4 HSE, is that not petrol? Got - 2017 SDV8 Autobiography in Loire Blue
Post #628226 9th Apr 2022 8:52pm
Rob99
Re: wrong fuel
But, cant find the tool to deactivate the inline wrong fuel thing. Plus does anyone know how to drain the fuel out? It's a full tank too!.
I thought the wrong fuel device was supposed to operate BEFORE you filled the tank up Whistle 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #628245 10th Apr 2022 7:42am
