Home > Maintenance & Mods (L405) > wrong fuel |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
Get a long screwdriver down the filler neck and move the wrong fuel thing back to its resting place , shine a torch down, its dead easy . The tool is normally in the boot, rhs stuck in the foam beside the spare wheel. If you have one, watch out as they easily break when you turn them. |
9th Apr 2022 7:05am |
splud Member Since: 28 Feb 2019 Location: WA Posts: 3 |
Thanks, I was ment to post in the L405 forum as I got a new/ 2nd hand one. |
9th Apr 2022 7:09am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6731 |
I think the secret is not to start the car so the (wrong) fuel gets pumped around the system, which will be VERY expensive to fix. There are a few companies who can come to you on the forecourt and suck it out with the minimum of damage.
9th Apr 2022 7:36am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
Sorry, I did not see this sooner as I might have been a help, A mate did the same a few weeks back and I took all my jerry cans to the servo and with an old electric fuel pump and a bit of hose drained his tank. Although not recommended there seems a view that 5% petrol in diesel won't do any harm. We put 10 litres of diesel in the empty tank and drained that before filled with diesel. The car started and ran with zero issues.
9th Apr 2022 7:52am |
Many thanks, I did drive it only for 5kms, however it did start coughing. I'll try emptying the tank and putting some diesel in it and empty again. Thanks everyone. |
9th Apr 2022 9:13am |
Probably a silly question but your car description says you have a 2005 4.4 HSE, is that not petrol? Got - 2017 SDV8 Autobiography in Loire Blue
9th Apr 2022 8:52pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1431 |
I thought the wrong fuel device was supposed to operate BEFORE you filled the tank up 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
10th Apr 2022 7:42am |
