Home > In Car Electronics (L322) > Where’s my phone book? 2012 Westie |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
Do you have an IID tool? I lost my phone book on my 2012 AB went into the tool and found that the DAB was not on and other functions? it's working now so worth a look? |
8th Apr 2022 4:31pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
It might be worth checking that the setting on your phone hasn’t changed.
8th Apr 2022 5:03pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 228 |
I don’t have IID but my specialist said there were no fault codes of any kind and everything was showing as it should. DAB is working fine. Phone settings are unchanged. 2012 4.4 TDV8 Westminster
8th Apr 2022 5:14pm |
My tool did not show any faults just that stuff was not turned on? I also checked on Apple forum for problems with phones after updates? |
8th Apr 2022 5:19pm |
I may pop back next week and see what’s what in that case. 2012 4.4 TDV8 Westminster
8th Apr 2022 5:35pm |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 119 |
Be sure to double check the settings on the phone too to make sure it’s syncing the contacts. Go Bluetooth, click the blue i next to the connection and make sure all is as it should be. |
8th Apr 2022 6:06pm |
Never changed.
8th Apr 2022 7:32pm |
RutlandBoy Member Since: 20 Mar 2022 Location: East Northants Posts: 31 |
Hi,
8th Apr 2022 8:34pm |
When I turned things on, I told the car to update the settings? the system reloaded it was then it came back on.
9th Apr 2022 7:44am |
