Home > Technical (L322) > Live Height Sensor Values |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
Did you calibrate it after changing the sensors? When it's standing on a flat surface what are the actual height on each hub - are any significantly up or down? 2012 TDV8 Vogue (L322) |
5th Apr 2022 6:34pm |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 |
Yes after they were fitted the Height was calibrated using the IID tool.
6th Apr 2022 1:26pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
5 to 10mm is massive, I've got mine to within 2mm.
6th Apr 2022 2:07pm |
It will only adjust itself if the actual hub is more than +/- 10mm from the calibrated setting. Obviously when calibrating you get it as close to zero as possible. AFAIK 30mins after shutdown it will wake up and level itself and this is where a bad calibration or iffy height sensor will cause the whole car to drop. 2012 TDV8 Vogue (L322) |
6th Apr 2022 2:12pm |
