Home > Technical (L322) > Live Height Sensor Values
Jon G
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Evening All
Been looking at Live Values of the Height Sensors tonight.
Car was sat parked on the drive and it showed the Values below.
Rears are quite similar but the Fronts seem very different.
Both Front Sensors have been changed in the last couple of months, so I was wondering if this is right or do I have a
problem ?
Post #627833 5th Apr 2022 6:04pm
JayGee
Did you calibrate it after changing the sensors? When it's standing on a flat surface what are the actual height on each hub - are any significantly up or down? 2012 TDV8 Vogue (L322)
Post #627835 5th Apr 2022 6:34pm
Jon G
Yes after they were fitted the Height was calibrated using the IID tool.
Heights are within 5 to 10mm side to side.
Post #627936 6th Apr 2022 1:26pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
5 to 10mm is massive, I've got mine to within 2mm.
You need to do it when the car/compressor is cold I have noticed or the adjustment can be really sluggish. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #627941 6th Apr 2022 2:07pm
JayGee
It will only adjust itself if the actual hub is more than +/- 10mm from the calibrated setting. Obviously when calibrating you get it as close to zero as possible. AFAIK 30mins after shutdown it will wake up and level itself and this is where a bad calibration or iffy height sensor will cause the whole car to drop. 2012 TDV8 Vogue (L322)
Post #627942 6th Apr 2022 2:12pm
