Home > Technical (L322) > TDV8 4.4 Restricted Performance - P004B-71 Actuator Stuck
Baltic Blue
The connector circled yellow is the one that was off on mine, as detailed in the link I posted.
Has your CSOV got a nut on the top??
If so I would be tempted to remove it , allowing you to lift the arm and work in some oil/ WD40.
Mike.
PS.
A bit more background….
When mine was stuck and I got R.P., I called LR Assist.
He just squirted it with WD 40 but it didn’t free so he booked it in with my supplying MD, so when they got it they replaced the complete unit and it has been fine ever since.
Post #627829 5th Apr 2022 5:31pm
davethomas83
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Was just about to say, after studying on a big screen rather than my phone, realized its the same connector ( mine being plugged in )
Yeah its old style, so assuming weather holds out tomorrow, ill get some contact cleaner on that connector, and then loosen the nut and give it a good old spray
Post #627830 5th Apr 2022 5:35pm
davethomas83
Mike.
PS.
Mike.
Mines booked in with the Indy, but he cant get me in until May Big Cry so although i have that appointment booked, hoping to sort myself before then
Post #627832 5th Apr 2022 5:44pm
