Home > Technical (L322) > TDV8 4.4 Restricted Performance - P004B-71 Actuator Stuck |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3246 |
The fault happened after you cleaned up the front and removed the pipes? 2012 TDV8 Vogue (L322) |
31st Mar 2022 12:26pm |
davethomas83 Member Since: 12 Dec 2015 Location: Gloucester Posts: 30 |
Yep, it certainly wasnt there before.
31st Mar 2022 12:46pm |
I guess you have your answer 2012 TDV8 Vogue (L322) |
31st Mar 2022 12:49pm |
ok, so ive checked all the pipes, and i cant see any issues there, so im guessing the actuator is actually stuck.
4th Apr 2022 4:18pm |
My experience with turbo actuators on other cars is that the rod from the pressure capsule moves but it can be very stiff as depending on what 'cracking' pressure it's rated at it may have a very stiff spring. Normally you would test by removing the pressure feed and attaching an airline and pressure gauge and seeing at what pressure it opens and also checking for any air leaks. 2012 TDV8 Vogue (L322) |
4th Apr 2022 4:27pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2487 |
The actuating chamber is vacuum operated so the shaft moves into the chamber rather than away, as would be the case with a pressure chamber. |
4th Apr 2022 8:22pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
My Indy took mine off & cleaned it all up, so I’m assuming it’s not a difficult task to do as he didn’t charge me for it! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
5th Apr 2022 7:18am |
ok so ive been under the car today, and sprayed it to death, and oiled it - as far as i can tell it moves ok ( assuming im moving the correct bit that is )
5th Apr 2022 2:48pm |
If the actuators are driven from the vacuum unit and not from turbo charger boost then the solenoid may not be where the actuator is. 2012 TDV8 Vogue (L322) |
5th Apr 2022 2:54pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
https://www.fullfatrr.com/forum/topic60579.htm
5th Apr 2022 3:22pm |
Hi Mike - link giving me 404 not found |
5th Apr 2022 3:24pm |
https://www.fullfatrr.com/forum/topic60579.html
5th Apr 2022 3:28pm |
P004B-71
5th Apr 2022 4:32pm |
so . . . .
5th Apr 2022 5:15pm |
