Home > Maintenance & Mods (L322) > 4.4 TDV8 - who's a sucker and who's a dumper?
Oil Change Method
Suck
64%
 64%  [18]
Dump
35%
 35%  [10]
Total Votes: 28
garyRR
So, I'm torn on whether to get a transfer pump or not. I'm currently a dumper with a bucket to do it in. It cost me £1.50 and is much more hygienic than a shallower drain pan, risking splashback.
Pros and cons of each method?
My assumption is that dumping is more likely to get the crud out but I don't know if this is true - whether sucking is actually more effective at getting all the oil and all the crud out. 2015 Range Rover Autobiography 4.4 SDV8
Post #626475 19th Mar 2022 10:05am
GraemeS
Having found nothing more than a few drips from the removed hose connection after using a suction pump, I now only remove the drain plug for the turbo drain reservoir during every 2nd or 3rd oil change. Mine's hose connecter gets filled with dirt which is troublesome to clean to allow it to be disconnected so that discourages me from going back to draining from there.
Post #626481 19th Mar 2022 11:05am
JayGee
I'm a converted sucker. Draper expert is so easy to use. Regular oil changes with the specified oil and there shouldn't be any sludge to worry about. 2012 TDV8 Vogue (L322)
Post #626489 19th Mar 2022 1:01pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Independent annual service dumps and I do two further oil changes from the top in between using a Draper vacuum unit.
Serious overkill for the mileage I do but oil is cheap compared to the cost of a new engine. Forty years of progress. 1972-2012
Post #626505 19th Mar 2022 8:23pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Draper for me, although I lent mine to a mate and this has just reminded me that he hasn’t given it back yet Neutral
Post #626531 20th Mar 2022 12:08pm
DrRob
Ditto but just one home sucking oil change for me between independent specialist service Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626554 20th Mar 2022 6:26pm
JayGee
Do specialist Indy workshops suck or dump? 2012 TDV8 Vogue (L322)
Post #626555 20th Mar 2022 6:35pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I know mine dumps, as he managed to strip the drain plug threads (repaired gratis).
JD automotive. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #626563 20th Mar 2022 7:50pm
knwatkins
I used to be a dumper, now I'm a sucker.
I don't understand why the draper vacuum pump is such a big hitter on the forum, compared to a little 12V pump which is much cheaper and isn't restricted on capacity.
I have one of these and it drains all 9.4 litres out within a couple of minutes, straight into my container which I take to the local recycling centre. I paid £11 at the time. Looks like it's £13 now...
https://www.ebay.co.uk/itm/134035200459 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #626581 20th Mar 2022 9:48pm
garyRR
How long have you had the pump? Some of the 12V ones I've seen videos of seem very slow or unable to get the whole sump contents. Getting all 9.4L is encouraging however - by dumping I normally get around 8.7L. 2015 Range Rover Autobiography 4.4 SDV8
Post #627775 4th Apr 2022 10:20pm
knwatkins
I've had it for around about 16 months now Gary. I've used it for two changes so far. As long as the engine oil is nice and warm the full 9.4 litres is out within a few minutes. Kev
Post #627777 5th Apr 2022 1:29am
Mikey
Sump plug out Thumbs Up
Post #627778 5th Apr 2022 4:19am
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Draper pump all day long. Did mine this evening just as an interim oil change. I bought it a couple of years ago when I had a Disco 4, never looked back.
Post #627844 5th Apr 2022 8:19pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I've got a sealey vacuum that I've owned for years. I used that to change my PAS fluid too as I vac'd the system down and kept topping up the reservoir until new fluid came through. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #627909 6th Apr 2022 10:38am
