Home > Maintenance & Mods (L322) > Front brakes and clean up
Finished my front brake change today along with a clean up of the areas underneath. My car had quite a bit of rust on the chassis and suspension components, so a good wire brush and a coat of paint and looks a load better.
[/url]
IMG_0931_002[/img]
Before
[/url]
IMG_0932_003[/img]
After
Post #62766 5th May 2011 5:21pm
pretlove
looks good Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #62778 5th May 2011 6:06pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Looks really good, did you find an improvement in brake performance?
I need to clean up the underside of my FF, stupid question time: did you use a full on stiff wire brush, and what paint did you use?
Thanks in advance 2008/58 FFRR 3.6 TDV8 Vogue
Post #62907 6th May 2011 8:59pm
3R10
France
Looks really good! What kind of rotors are those if you don't mind asking? 2000 BMW M5, Avus Blue/LeMans Leather Interior
2006 Range Rover Westminster Java Black
Post #62908 6th May 2011 9:09pm
Up to now I haven't noticed an improvement but there still bedding in. Hope there will be some improvement once the rears are done and bedded in. I used a stiff wire brush and then used hammerite smooth black. Can be painted direct to rust and is ment to stop it but not 100% sure that will happen, maybe slow it a bit. The rotors are britpart. Didn't want drilled and slotted just played to prevent rust but only ones I could find were these. Wanted the anticorrosion for the rears really so had to get a matching set.
Post #62918 6th May 2011 10:18pm
