Home > Technical (L322) > CV Joint Grease - How much of it?
dhallworth
I’m replacing both the inner and outer gator on both rear driveshafts as one had been bodged in the past.
I bought two GKN kits from Island 4x4. However, each kit has come with a mega amount of grease. There’s about 6 sachets per kit.
I’m guessing I don’t need it all as it’ll just spill out and make a right old mess.
Does anyone know what the right amount to put in is after I’ve flushed and cleaned both joints?
There’s 5 sachets of Genuine Grease for CV joints and 2 sachets of Optimol. The Optimal feels heavier. 🤷🏻‍♂️
Thanks
Post #627555 1st Apr 2022 7:02pm
dhallworth
Right:
The 2 heavier packs of grease (Optimol MS139G) are used on the Outer joint.
The 5 packs of lighter grease (MS141G) are used on the bigger inboard joint. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #627561 1st Apr 2022 7:50pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Only JLR would use different grease for each side of a drive shaft. Rolling Eyes
Post #627677 3rd Apr 2022 8:03pm
dhallworth
Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #627678 3rd Apr 2022 8:38pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I’m replacing the outer CV boot (front driver side) on my L322 after it was damaged by Bourton LR when replacing the suspension arms & ball joints (these things happen but they flatly denied doing this despite the obviously fresh dint in the clip where the split is and CV grease leaking out a matter of a few miles afterwards yet no call from them whilst doing the job that it was already leaking, that logic was lost on them when I went back - shame as I’ve used them a few times previously without issues…).
I have the genuine GKN boot kit; outer & inner boots / clips & several packs of CV grease - I’m only replacing the outer boot. Ref. David’s post above, do I take it I use two sachets of the supplied grease in the joint?
Thanks Thumbs Up Jonathan
2007 Defender 90 XS Hardtop
Post #685780 16th Feb 2024 3:15pm
