Home > Technical (L322) > new rear discs and pads needed shortly - are these ok?
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
corrosion around hub and outer 'rim' and are 'squealing'
going to get my 'jeep' guy to do them
seen these Brembo discs on fleabay are they correct please?
2005 4.4 V8
item eBay Item No. 330552584671
sorry cannot do links!
Post #62587 4th May 2011 10:39am
Brembos only fit the later cars AFAIK with a certain wheel type
What's your car and wheels etc? Discovery 4 HSE
Post #62588 4th May 2011 10:40am
nick h
thanks
2005 4.4 V8 with 20"wheels
according to the details on the ebay item and following their link they should fit?
any alternatives gratefully accepted
thanks
edit
from Brembo's OWN catalogue there are two
08.6838.10 304 x 12.6 - used for cars with '..3A..' in VIN number
08.8554.20 354 x 12 - used for cars with '..5A..' in VIN number
any help?
edit to add model ref's to each type of disc
Post #62592 4th May 2011 11:21am
nick h
no advice/comment with the info provided that was asked for?
Post #62603 4th May 2011 1:11pm
pretlove
nick they seem to be the right ones you dont have to have brembo brakes to have those discs ....
also before i forget thanks for the rear badge Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #62621 4th May 2011 3:17pm
nick h
thanks Thumbs Up
its the calipers that can cause problems with some earlier models
Post #62693 5th May 2011 4:57am
nick h
Dan any comment as you know the 'system' so well?
thanks
Post #62729 5th May 2011 1:30pm
Martin
Site Admin
Brembo supply aftermarket discs for lots of makes/models, not just the cars with factory fitted show-off Brembo calipers Wink
Post #62754 5th May 2011 4:08pm
Martin
Site Admin
The 304mm disc 08.6838.10 cross refers to LR part SDB000470 which is for P38 Range Rover and Disco2
The 354mm disc 08.8554.20 cross refers to LR part SDB000210.
Rear disc options are:
SOP to 3A129289: SDB000210 use SDB000211
3A129290 to 5A999999: SDB000211 Solid, 354mm dia., thickness 12mm
6A000001 to 6A228066: SDB500201 use LR017804
6A228067 to 9A999999: SDB500202 use LR017804
AA000001 on (3.6 TDV8/5.0 NA: LR017804 Ventilated, 354mm dia., thickness 20mm
AA000001 on (5.0 SC/4.4 TDV8): LR011891 No Info - assume Ventilated and >354mm dia.
Assuming your car is before the 06MY change to ventilated discs, it looks like the SDB000211 is right for your car, so Brembo number 08.8554.20
Post #62756 5th May 2011 4:22pm
nick h
thanks
Post #63110 9th May 2011 12:12pm
dan_uk_1984
Sorry, I was going to reply. Then, on the balance of things I decided not to.
Sheep
Post #63143 9th May 2011 4:07pm
