Home > Technical (L322) > new rear discs and pads needed shortly - are these ok? |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
corrosion around hub and outer 'rim' and are 'squealing'
4th May 2011 9:39am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Brembos only fit the later cars AFAIK with a certain wheel type
4th May 2011 9:40am |
no advice/comment with the info provided that was asked for? |
4th May 2011 12:11pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
nick they seem to be the right ones you dont have to have brembo brakes to have those discs ....
4th May 2011 2:17pm |
thanks its the calipers that can cause problems with some earlier models |
5th May 2011 3:57am |
Dan any comment as you know the 'system' so well?
5th May 2011 12:30pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Brembo supply aftermarket discs for lots of makes/models, not just the cars with factory fitted show-off Brembo calipers |
5th May 2011 3:08pm |
The 304mm disc 08.6838.10 cross refers to LR part SDB000470 which is for P38 Range Rover and Disco2
5th May 2011 3:22pm |
thanks |
9th May 2011 11:12am |
Sorry, I was going to reply. Then, on the balance of things I decided not to. |
9th May 2011 3:07pm |
