Home > Maintenance & Mods (L322) > Oil on the driveway |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Turbo
13th Mar 2022 8:35pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3231 |
Usual suspects are the oil cooler return pipe O rings and the oil cooler gaskets. Check your coolant expansion tank for oil contamination. It's very unusual for the oil cooler gaskets not to fail on these engines at some point it seems..... 2012 TDV8 Vogue (L322) |
14th Mar 2022 8:08am |
Oil cooler gasket or O rings is where I'd put my money on Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Mar 2022 8:56am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
I had spots of oil on my driveway and was lucky enough to catch it quickly before there was oil in the coolant (2012 TDV8). As has been said, I'd put money on it being the oil cooler gaskets and/or the o-rings on the oil feed pipe to the cooler.
14th Mar 2022 1:26pm |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 143 |
Thanks everybody for your replies,
24th Mar 2022 9:15pm |
Henshall Engineering in Cheshire is a top recommendation Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Mar 2022 7:53am |
It’s an inevitable issue with these engines. If you are lucky the previous owner has had it done. It’s fiddly but easily within the scope of a DIY job which will save you a lot as you will be paying for time mainly as long as the cooler is not cracked. 2012 TDV8 Vogue (L322) |
25th Mar 2022 8:01am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1189 |
Flushing the coolant after will take some time as well. |
25th Mar 2022 8:28am |
First quote £650 if the problem is down to gaskets only, providing cooler is not warped, otherwise £1200 for a new LR cooler fitted, both prices plus VAT! Independent garage. Don't think I will be going there.
31st Mar 2022 4:45pm |
If the independent is changing the oil and coolant at that price, that's certainly where I'd be going (other than doing it myself). I wouldn't be fitting a cheap and nasty non-genuine oil cooler. They may tell you that the cooler is warped, but I doubt it. Besides, will they have proper equipment to confirm this anyway? The older I get, the more I realise that people confuse wrinkles for wisdom |
31st Mar 2022 6:30pm |
Both quotes are from independent land rover specialist and are both recommended by various users.
31st Mar 2022 7:25pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
Here are the costs for my oil cooler replacement. total 6 hours (I also had the Gearbox and transfer box oils changed.)
1st Apr 2022 11:21am |
What was the total cost and did you do the job yourself ? RR owner |
1st Apr 2022 2:56pm |
The lower priced quote includes an OEM cooler which I think is OK, any comments welcome. RR owner |
1st Apr 2022 4:23pm |
