Home > Technical (L322) > Restricted Performance Warning & DPF Full amber light
Page 3 of 3 <123
Fox889
Have to say, 3000rpm ain’t the way to go for a regen old matey.
Gentle amble at 55-65mph, 1150rpm, in top, on cruise & she’ll be fine, try that & see if it helps? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #627510 1st Apr 2022 7:18am
Dolphinboy
@Jaygee
I disagree that a leak could cause this situation. My DPF yellow and red faults were caused by a minute crack in the pax inlet manifold which only gave RP on occasions but then filled the DPF. They couldn't find it at first but a HIGH pressure smoke test did the job.
I only have very limited mech knowledge and you seem to have good mech background so I will defer if required. Thumbs Up
Post #627521 1st Apr 2022 11:07am
Dolphinboy
JayGee wrote:
some other system or sensor fault is stopping it going into an active regen and this will only be revealed when you get it scanned.
The reason why mine wouldnt regen was the thermostat housing had been damaged by a previous garage and so the engine (which runs very cool anyway) couldn't reach the temp for a regen to take place - it would initiate (sometimes thousands of attempts an hour!) but never complete, due to the internal engine temp being too low as the thermostat was open all the time.
Post #627522 1st Apr 2022 11:11am
JayGee
Specific experience is worth more than general mechanical experience on these cars so happy to be corrected 2012 TDV8 Vogue (L322)
Post #627523 1st Apr 2022 11:13am
Crusty21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
MUCH APPRECIATE ALL THE HELP GUYS!
It seems that from people's experience on here that there is a hole load of issues that could cause the specific problem so the vehicle is now booked in for a scan so the garage can sort it out Mr. Green
When I get the results back I will post here so that it may help somebody out in the future
Incidentally, took it up the M57 this morning to see a client and after just 10 miles @ 70mph the DPF amber warning light went out again Laughing Laughing Laughing Laughing Laughing
That's 4 times this week ..... warning light ON ...... motorway run ..... warning light OFF ...... and REPEAT
It's all a bit Groundhog Day Laughing Laughing Laughing
KR
Neil 2011 TDV8 4.4 Vogue SE
Post #627527 1st Apr 2022 11:27am
Baltic Blue
Many owners have reported cracks and hose slits so minute that they didn’t show up on low pressure smoke tests, but gave all these DPF warning problems, yet as soon as located using a high pressure smoke test, no further problems.
Post #627528 1st Apr 2022 11:42am
GGDR
9.5 times out of 10 it is a boost leak
. Cheers, Greg
Post #627530 1st Apr 2022 12:03pm
Dolphinboy
KR
Neil
slightly leftfield, but have you checked the sensors on the exhaust pipe (ie before and after the exhaust box) are situated correctly, i.e not lose or dislodged slightly, ad not fouled/dirty. It may only be one of the sensors there needs replacing. the IID tool will tell you the voltage emanating from each sensor so have a gander at that.
Post #627542 1st Apr 2022 2:54pm
Range Rover L322
JayGee wrote:
An intake leak big enough to cause excess soot via overfueling would throw an engine fault which is easier to identify with a fault scan than a high pressure smoke test IMO. Getting fault scan is the first and main priority.
Apologies for contradicting you but this is not the case.
The majority of leaks will give a DPF Full warning but no engine fault. High Pressure smoke test always the first stop and will find it in 90% of cases.
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #627569 1st Apr 2022 9:55pm
JayGee
No need for apologies as happy to be fully corrected on this one. 2012 TDV8 Vogue (L322)
Post #627576 2nd Apr 2022 7:11am
Smitch
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
I went through a lot of pain with this issue.
If the short hoses are leaking it’s usually from underneath so loosen the clips and spin them, you will see a distinct sooty deposit on the clip as a tell tale sign.
The intake hose can be fixed by tightening the clip, however, I’ve seen a good few now where the leak is actually coming from the sensor housing on the pipe (this looks like the area you had a lot of build up)
This was mine
Post #627750 4th Apr 2022 7:10pm
Page 3 of 3 <123
