Home > Technical (L322) > Restricted Performance Warning & DPF Full amber light |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
@Jaygee
1st Apr 2022 11:07am |
The reason why mine wouldnt regen was the thermostat housing had been damaged by a previous garage and so the engine (which runs very cool anyway) couldn't reach the temp for a regen to take place - it would initiate (sometimes thousands of attempts an hour!) but never complete, due to the internal engine temp being too low as the thermostat was open all the time. |
1st Apr 2022 11:11am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3196 |
Specific experience is worth more than general mechanical experience on these cars so happy to be corrected 2012 TDV8 Vogue (L322) |
1st Apr 2022 11:13am |
Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 16 |
MUCH APPRECIATE ALL THE HELP GUYS!
1st Apr 2022 11:27am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Many owners have reported cracks and hose slits so minute that they didn’t show up on low pressure smoke tests, but gave all these DPF warning problems, yet as soon as located using a high pressure smoke test, no further problems.
1st Apr 2022 11:42am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
9.5 times out of 10 it is a boost leak
1st Apr 2022 12:03pm |
slightly leftfield, but have you checked the sensors on the exhaust pipe (ie before and after the exhaust box) are situated correctly, i.e not lose or dislodged slightly, ad not fouled/dirty. It may only be one of the sensors there needs replacing. the IID tool will tell you the voltage emanating from each sensor so have a gander at that. |
1st Apr 2022 2:54pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Apologies for contradicting you but this is not the case. The majority of leaks will give a DPF Full warning but no engine fault. High Pressure smoke test always the first stop and will find it in 90% of cases. . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
1st Apr 2022 9:55pm |
No need for apologies as happy to be fully corrected on this one. 2012 TDV8 Vogue (L322) |
2nd Apr 2022 7:11am |
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 |
I went through a lot of pain with this issue.
4th Apr 2022 7:10pm |
