Home > Maintenance & Mods (L322) > Alternator. Change or not?
kevinp
I now have all the pulleys, tensioner and water pump and belts ready to fit.
Would it be foolhardy not to change the alternator at the same time?
I didn't have any service history with the car which has now done 110,000 miles so I don't know if it has ever been changed.
Has anyone had theirs fail and if so what mileage approx.
I don't want to spend money for moneys sake but then again it's quite a big job to do I believe.
Thanks Kev.
Post #627367 30th Mar 2022 5:48pm
Bantam
2007 Range Rover Vogue SE TDV8 Java Black
For what its worth, I had my (failed) alternator changed at an Indi - mileage was 75k ish. The guy told me that they either fail around that mileage or go on to 150k without any issues.
On a 2007 V8 it looked a big job to me - he changed the starting heaters at the same time - small extra cost and worth doing whilst it was in 1000 pieces Smile
Post #627375 30th Mar 2022 6:49pm
dingg1
Mine failed about 100k, bearings were fine, brushes were fine with plenty meat left, rectifier issue, I'd change it if I were you tbh.
Post #627408 31st Mar 2022 12:26am
JayGee
AFAIK the alternator on the 4.4V8 is better than earlier ones with no issues concerning the rectifiers but considering how much you are removing to get the belts and waterpump done it seems sensible to replace it while it's easy to get at unless you are on a very tight budget (£250ish) - just one less thing to worry about. 2012 TDV8 Vogue (L322)
Post #627418 31st Mar 2022 7:19am
kevinp
Thanks for your replies. Do I gather the Denso LR072762 is the one to go for?
Post #627419 31st Mar 2022 7:42am
JayGee
AFAIK Denso is the factory fit. 2012 TDV8 Vogue (L322)
Post #627421 31st Mar 2022 7:44am
GraemeS
My 4.4's failed at 150K kms. It was obvious that 1 diode had failed as the insulation on the winding from that diode was burnt. I suspect other diodes weren't far behind.
The bearings, slip rings and brushes showed no sign of wear and the inside of the alternator was very clean, which was surprising as I go through lots of mud far too often.
Post #627426 31st Mar 2022 7:55am
JayGee
I should have had the garage change mine when they did the belts and water pump Embarassed 2012 TDV8 Vogue (L322)
Post #627428 31st Mar 2022 7:58am
GraemeS
Denso DAN1110
Post #627432 31st Mar 2022 9:10am
kevinp
Thanks for all your input.
Post #627437 31st Mar 2022 9:53am
kevinp
My local indie getting one for tomorrow. Not to bad at £234. Thanks all.
Post #627439 31st Mar 2022 10:08am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
That’s a good price that Kevin if its a Denso. Thumbs Up
Post #627440 31st Mar 2022 10:10am
kevinp
I thought so Dave. Opie oils had a 15% discount code which made theirs £235 so my Indie undercut it by a £1.
Fingers crossed and all that.
Post #627454 31st Mar 2022 1:15pm
kevinp
So I now have a nice shiny Denso alternator. Just got to pluck up the courage to fit it all now. Big Cry
Post #627531 1st Apr 2022 12:15pm
GraemeS
I found the screws in the bottom of the radiator shroud a pain to remove. I've since acquired a battery-operated 3/8 ratchet in case I have to R&R the shroud again in the hope that the task should be easier.
Post #627562 1st Apr 2022 7:43pm
