Home > Maintenance & Mods (L322) > Alternator. Change or not? |
Bantam Member Since: 20 Feb 2012 Location: Cheshire Posts: 27 |
For what its worth, I had my (failed) alternator changed at an Indi - mileage was 75k ish. The guy told me that they either fail around that mileage or go on to 150k without any issues.
30th Mar 2022 6:49pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
Mine failed about 100k, bearings were fine, brushes were fine with plenty meat left, rectifier issue, I'd change it if I were you tbh. |
31st Mar 2022 12:26am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3232 |
AFAIK the alternator on the 4.4V8 is better than earlier ones with no issues concerning the rectifiers but considering how much you are removing to get the belts and waterpump done it seems sensible to replace it while it's easy to get at unless you are on a very tight budget (£250ish) - just one less thing to worry about. 2012 TDV8 Vogue (L322) |
31st Mar 2022 7:19am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1214 |
Thanks for your replies. Do I gather the Denso LR072762 is the one to go for? |
31st Mar 2022 7:42am |
AFAIK Denso is the factory fit. 2012 TDV8 Vogue (L322) |
31st Mar 2022 7:44am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
My 4.4's failed at 150K kms. It was obvious that 1 diode had failed as the insulation on the winding from that diode was burnt. I suspect other diodes weren't far behind.
31st Mar 2022 7:55am |
I should have had the garage change mine when they did the belts and water pump 2012 TDV8 Vogue (L322) |
31st Mar 2022 7:58am |
Denso DAN1110 |
31st Mar 2022 9:10am |
Thanks for all your input. |
31st Mar 2022 9:53am |
My local indie getting one for tomorrow. Not to bad at £234. Thanks all. |
31st Mar 2022 10:08am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
That’s a good price that Kevin if its a Denso. |
31st Mar 2022 10:10am |
I thought so Dave. Opie oils had a 15% discount code which made theirs £235 so my Indie undercut it by a £1.
31st Mar 2022 1:15pm |
So I now have a nice shiny Denso alternator. Just got to pluck up the courage to fit it all now. |
1st Apr 2022 12:15pm |
I found the screws in the bottom of the radiator shroud a pain to remove. I've since acquired a battery-operated 3/8 ratchet in case I have to R&R the shroud again in the hope that the task should be easier. |
1st Apr 2022 7:43pm |
