![]() | Home > Technical (L322) > Restricted Performance Warning & DPF Full amber light |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Firstly, welcome to the forum, you are amongst 4.4 tdV8 friends on here with plenty of experience between us.
Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 30 ![]() ![]() ![]() |
Thanks Mike
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Firstly, welcome.
I usually recommend wiping around all the pipes with a clean white tissue / kitchen roll paper, looking for sooty oil leaks, but I have just seen your pictures and at first glance they look nice and dry, so next suspect would be the throttle body hose being loose.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
100% recommend Henshall Engineering close to you. Old skool but they will find the issue quickly for you.
Thanks again Mike
Just pull out the wire clip and pull the hose off to wipe it clean, then bend the clip carefully to add more tension before re-fitting. Very common fault.
Thanks DrRob
Thanks Mike
S60R Member Since: 23 Mar 2022 Location: West Sussex Posts: 50 ![]() ![]() |
IID tool for sale over on D3...
Thanks for the heads up |
Get the IID tool, run a scan and report back. Everything else is a stab in the dark but likley short trips over a long time will generate a DPF full light. Needs long sustained 50mph + to initiate a DPF cleaning cycle rather than a short blast. 2012 TDV8 Vogue (L322) |
UPDATE |
