Home > Technical (L322) > Restricted Performance Warning & DPF Full amber light |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Firstly, welcome to the forum, you are amongst 4.4 tdV8 friends on here with plenty of experience between us.
29th Mar 2022 1:47pm |
Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 16 |
Thanks Mike
29th Mar 2022 2:35pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2641 |
Firstly, welcome.
29th Mar 2022 3:09pm |
29th Mar 2022 3:32pm |
I usually recommend wiping around all the pipes with a clean white tissue / kitchen roll paper, looking for sooty oil leaks, but I have just seen your pictures and at first glance they look nice and dry, so next suspect would be the throttle body hose being loose.
29th Mar 2022 4:26pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
100% recommend Henshall Engineering close to you. Old skool but they will find the issue quickly for you.
29th Mar 2022 5:05pm |
Thanks again Mike
29th Mar 2022 5:27pm |
Just pull out the wire clip and pull the hose off to wipe it clean, then bend the clip carefully to add more tension before re-fitting. Very common fault.
29th Mar 2022 5:31pm |
Thanks DrRob
29th Mar 2022 5:33pm |
Thanks Mike
29th Mar 2022 5:35pm |
S60R Member Since: 23 Mar 2022 Location: West Sussex Posts: 50 |
IID tool for sale over on D3...
29th Mar 2022 6:11pm |
Thanks for the heads up Appreciate it 2011 TDV8 4.4 Vogue SE |
29th Mar 2022 6:14pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3196 |
Get the IID tool, run a scan and report back. Everything else is a stab in the dark but likley short trips over a long time will generate a DPF full light. Needs long sustained 50mph + to initiate a DPF cleaning cycle rather than a short blast. 2012 TDV8 Vogue (L322) |
29th Mar 2022 7:16pm |
UPDATE
30th Mar 2022 1:14pm |
