Home > Maintenance & Mods (L322) > Are callipers serviceable items?
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Rear callipers are in different stages of piston crud / corrosion.
LHS is mostly clear. Can get under the rubber boot with brake cleaner and small brush and clean most of crud out
RHS is crudded up. Piston will only retract about half way into calliper. Was unable to retract piston far enough to fit new set of pads, so one new pad and one partly worn installed for now.
Are these callipers serviceable so that pistons can be removed and cleaned / polished, body also cleaned, new boot / seal installed and piston re-installed, and bled
Or are they chuck away?
Maybe there are service kits out there with new pistons and seals?
Post #627137 28th Mar 2022 9:38am
cass
They are serviceable but I got Bearmach ones for less than £40 each, no exchange, so it's not worth the trouble of rebuilding them.
Post #627140 28th Mar 2022 10:02am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I serviced my rear callipers for about a tenner a side. It's just a seal kit, piston and new bleed nipple.
The originals are TRW and they are about £200 each to buy new. I personally would rather have a reconditioned TRW calliper than a cheap and cheerful replacement.
https://www.fullfatrr.com/forum/topic61540-30.html Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #627142 28th Mar 2022 10:06am
Rambles
Thank you Caesium
Just a thought on removing the corroded piston
Did you try applying the brake with the calliper off to see if the hydraulics would force the piston out? (Done in some kind of receptacle to catch any escaping fluids …)
Love those mini clamps you used on the brake lines.
Makes my idea to use small circlips quite Neanderthal
Post #627148 28th Mar 2022 3:03pm
Caesium
I did think about using the pedal to push the piston out, however experience dictates this as a bad idea.
One is that I cannot see the calliper from the driver's seat whilst operating the pedal and two is that it was so tight that the subsequent release would probably have blown brake fluid everywhere and that stuff will take paint down to bare metal.
I wasn't prepared to take that risk. I knew I was replacing the pistons anyway so I pulled them out with G Clamps as you saw. Christian.
Current Cars
2019 BMW X4
or
Post #627153 28th Mar 2022 3:31pm
Rambles
Caesium
I ordered those parts myself today
I will fit on weekend
I noted the piston is not an “official” fit for the L322
Although it is sold by a few 4x4 specialists as being OK for L322s
Did you have any issue on fitting or since ?
Post #627210 29th Mar 2022 3:10pm
Caesium
There were two pistons from memory, one of them was stainless. I saw no point in a stainless one.
I got all the parts from Rimmer Bros as they were reasonable and when I spoke to them the guy was really helpful.
No problem with fitting at all, went back together really wasily, just used a smear of fresh brake fluid to lube the seals up. Dust boot popped in nice and easy. Christian.
Current Cars
2019 BMW X4
or
Post #627212 29th Mar 2022 3:44pm
