Home > Maintenance & Mods (L322) > Rear brake caliper Right part number but doesn’t fit |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1215 |
I've just been and measured the banjo bolt end on a new hose I've got and it does protrude 10mm, so that's right.
26th Mar 2022 12:13pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Hi Kevin Many thanks for the quick reply and for taking the time to check your banjo bolt for me. I do have the 6 pot Brembo on the front. Like you I’m thinking this is a manufacturing fault, it certainly looks as though it’s not tapped out deep enough. I’ve contacted the seller (well known LR parts seller) but suspect I won’t hear back now until Monday 2011 TDV8 Vogue SE |
26th Mar 2022 12:24pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 283 |
The TRW callipers come with a sort of aluminium plug in the banjo hole which can lead one to believe that it’s the wrong part - ask me how I know |
26th Mar 2022 8:01pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
I know I shouldn't....but.....
26th Mar 2022 8:44pm |
Now that I have stopped laughing....dennij, if you are in a tight corner and cannot wait to get the caliper exchanged, to get the car back on the road....one option is below
26th Mar 2022 9:00pm |
Interesting that you mention the aluminium cap, how did you manage to get it out? 2011 TDV8 Vogue SE |
27th Mar 2022 7:21am |
I seem to recall that it was threaded and I wedged a screwdriver or similar in and got it out; I’m going out to the shed soon so I’ll see if I still have the little plug - I’ve probably kept it in the ‘just in case tin’. |
27th Mar 2022 9:04am |
27th Mar 2022 2:29pm |
Cheers Jools, guess I should have read the picture book instructions 2011 TDV8 Vogue SE |
27th Mar 2022 4:17pm |
You are welcome, realising I’m not the only one has helped me regain a tiny bit of self-respect |
27th Mar 2022 4:48pm |
