![]() | Home > Maintenance & Mods (L322) > 36mm Viscous fan spanner |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
It’s a bit of a lottery to be honest, some come off easy while others seem to have been tightened up by the Incredible Hulk.
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Laser one is OK but obviously you risk a chance of damaging items if you needed to give it a thump to break the seal.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
I used one from Island 4X4, Still had to give a couple of good thumps before it shifted though. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
Thanks guys. |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
This is an easy one.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
£14 Halfords. Spray the nut first, drink a cup of tea, spray again. Put spanner on, and with a medium hammer, and a thick gloved right hand, hit the spanner to the right, and catch the spanner with the right hand. About 4 inches away. Takes a few. Hits. |
Thanks all for the useful information. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
I ended up using a cold chisel to get it loose |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Large adjustable spanner and an £8 ebay 36mm special . Clouted the adjustable once and the nut undid |
I bought a cheap 36mm open ended straight shaft spanner, put an extension tube on and it cracked off quite easy. Was expecting to struggle but it is quite a new fan so I'm happy. |
if you use a chisel, you are stressing the bearing on the water pump, with every hit...and that can make the seal fail, ...either will cause the water pump to leak/wear/fail. |
There was no other way to get it loose and more 2 years down the line, no water pump issues |
