Home > Maintenance & Mods (L322) > Lower tailgate strut
hotpotatojr
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Evening
I've recently changed both lower tailgate cables and and strut with genuine items.
Having never seen a "new" one work, I'm not sure if this is dropping properly. The strut seems to give up just short of the fully open position putting some stress on the cables. Is this normal or is the strut a duff?
Thanks
https://youtu.be/Dmo1zxQYsCM
Post #626921 24th Mar 2022 6:04pm
Merchy
As far as I understand, the strut is just for damping purposes, to stop the tailgate dropping in an uncontrolled manner, the cables are designed to take the weight of the tailgate and anyone sitting on it, seems normal to me.
Earlier cars only have cables, no strut / damper.
PS - It would be handy if you updated your profile so people could see which model you have. Thumbs Up
Post #626922 24th Mar 2022 6:27pm
hotpotatojr
Thanks - profile update.
Yep I understand how the cable/damper work, but the new damper seems to give up its 'damping' just short of the fully horizontal position. I'm sure I've seen an old thread with someone reporting the same on a new genuine damper so just wanted to double check.
Post #626923 24th Mar 2022 6:36pm
Merchy
Did not mean to do the teaching granny to suck eggs bit, someone with the same model as you should be along soon, my old bus does not have such luxuries!! Thumbs Up
Post #626933 24th Mar 2022 8:08pm
hotpotatojr
Thumbs Up thanks mate - I believe this can be retro-fit....but so far can't recommend!
Post #626934 24th Mar 2022 8:16pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
i have a 2012 and the bottom tailgate drops in a controlled manor all the way 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #626937 24th Mar 2022 8:29pm
hotpotatojr
Thanks I had a feeling it should do. I'll have to return it!
Tried it upside down just in case but it was worse.
Post #627006 26th Mar 2022 12:26am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Sounds like a similar problem I had with Britpart ones, their resistance is in the wrong direction!
Video of the problem I sent to Britpart. I ended up getting an LR one.
https://gopro.com/v/rDZmKwPamyEP8 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #627011 26th Mar 2022 9:38am
kevinp
Perfect description Caesium. I bought the crap Britpart ones as well!!
The stuff they sell really is poor quality.
Post #627012 26th Mar 2022 9:59am
Caesium
Don’t I know it. Had to replace my lower arms after 3 months because they’d worn out again. They were Britpart.
I’m really shocked to be frank because Britpart offer a 2 year warranty. How are they not going out of business?! Christian.
Current Cars
2019 BMW X4
or
Post #627015 26th Mar 2022 11:00am
