![]() | Home > Technical (L322) > Intermittent exhaust temperature sensor fault? Any advice? |
GTTURBO87UK Member Since: 16 Mar 2022 Location: Reading Posts: 27 ![]() ![]() ![]() |
Is there anything I need to do after refitting the ecu? I was told the egr blank is just done through the ecu |
Neanderthal Member Since: 25 Dec 2021 Location: Highlands Posts: 10 ![]() ![]() |
My understanding is that there's a physical blanking required.
Blanked the egr still getting this dam fault intermittently |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Those kits are for the 3.6 not the 4.4 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The exhaust temperature sensor on the dpf needed to be deleted |
