![]() | Home > Technical (L322) > Loose dip stick? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
This can happen if the oil circulation "vortex" filter gets blocked up (well it did on my TD6) something similar on a TDV8 ? .
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 133 ![]() ![]() ![]() |
Cheers Joe,
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Has anyone else had a dipstick issue? Today I went out and 10 mins in I noticed a fair amount of smoke under acceleration. A little time after I get the bong of doom, engine system fault. Stopped, turned off and restarted and all good. Drove to the next layby for a quick inspection and top front of the engine driver's side covered in oil. As I changed both top turbo hoses a few days back I thought maybe another hose split. After checking everywhere and finding no obvious leak I discovered the dipstick was out of the tube 1cm and the source of the oil leak. There is every chance I either did not replace it correctly or lifted it up with a rag or something so fingers crossed. Not sure why a not sealed dipstick would cause an engine systems error.
