![]() | Home > In Car Electronics (L322) > Electrics have died! But the battery is almost fully charged |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
It wouldn't hurt to try a hard reset. Disconnect the battery leads and leave disconnected for around 30 minutes, then touch the 2 leads together for around 30 seconds and then reconnect the leads back to the battery. I would also fully charge the battery prior to reconnecting just to be sure it's carrying the correct charge. 2011 TDV8 Vogue SE |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1215 ![]() ![]() ![]() |
Whilst you said that you charged the battery and said it was three quarters charged, have you measured the actual battery voltage ? Check that first and check all battery / earth connections. plus hard reset as in above post. |
Calvey Member Since: 24 May 2020 Location: Bucks Posts: 6 ![]() ![]() ![]() |
Well, I checked with the multimeter and its only reading 4.8v which could explain the problem. I had assumed (possibly incorrectly) the battery was ok because its only 18 months old and when it was serviced 2 months ago I was told the battery was as new.
Sounds like the battery may be goosed, had the same type of problem a while back, all kinds of weird faults, fitted new battery and bingo, all ok. At the time I was using an old battery charger, that gave false indications on the gauges |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1202 ![]() ![]() ![]() |
Our cars `MUST` have a good battery. I also had a new 18 month old battery that failed, it had a 2 year guarantee? when I returned it it was tested on the counter and was told nothing wrong? Goodbye. |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 ![]() ![]() ![]() |
Bear in mind that a new battery needs a battery reset in the diagnostics otherwise the alternator will cook it. Christian.
You could try connecting a battery charger and see if everything works, if it does new battery time. |
I agree about the quality of the battery.
